Early Rearview Mirror *Cracked* |
Targa70 |
Nov 15 2020, 02:42 PM
Member Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None |
So I broke the glass in my early rear view mirror as I was trying to coax it out, so I could tighten that damn screw.
Any ideas or experience on getting a new mirror into the plastic housing? I was considering going to a glass shop and have them cup a piece the same size to see if I can get it in. I would likely have them make 3 or 4 because I will need to "learn" how to get it back in. There may even be, in 2020, good high quality plastic that will fit the bill. Or does anyone have a mirror or the glass they would like to part with? Thanks for you consideration. |
Beach914 |
Nov 15 2020, 03:26 PM
Senior Member Group: Members Posts: 964 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
You can buy new replacement mirrors from Auto Atlanta.
Targa70 |
Nov 15 2020, 03:29 PM
PanelBilly |
Nov 15 2020, 04:06 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I didn't know that the glass could be replaced. How does the frame come apart?
rgalla9146 |
Nov 15 2020, 06:41 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Beach914 |
Nov 15 2020, 06:55 PM
My bad possibly. As I read others comments I may have assumed you were talking about the outside mirrors. I am not aware of replacements for the inside mirror and would stand corrected.
altitude411 |
Nov 15 2020, 07:14 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
So I broke the glass in my early rear view mirror as I was trying to coax it out, so I could tighten that damn screw. Any ideas or experience on getting a new mirror into the plastic housing? I was considering going to a glass shop and have them cup a piece the same size to see if I can get it in. I would likely have them make 3 or 4 because I will need to "learn" how to get it back in. There may even be, in 2020, good high quality plastic that will fit the bill. Or does anyone have a mirror or the glass they would like to part with? Thanks for you consideration. Are you talking about interior or exterior? Exterior replacement is the McMark method... go to post #12 in this thread. http://www.914world.com/bbs2/index.php?showtopic=42362 Glass, gaskets ect. can be found at 914 rubber (the other Mark (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) ) https://914rubber.com/exterior-mirror-glass-for-porsche-914 |
Nov 15 2020, 08:07 PM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There isn’t a way to take apart the inside mirror. I figured I might try to replace one of mine by getting the glass cut to the right size and heating it up with a heat gun.
Mikey914 |
Nov 15 2020, 08:39 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Let me know I can cut glass in quantity. I just didn't see how to easily replace it.
steuspeed |
Nov 16 2020, 03:07 AM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I have a 74 mirror. Is that early?
Cairo94507 |
Nov 16 2020, 07:01 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nope. That is the later, bigger mirror. I am not certain when they switched, but I know '70 and '71 were the small mirrors.
Targa70 |
Nov 16 2020, 07:04 AM
So it is the interior mirror I was looking to replace. When removing it, I used a couple of plastic pry tools and lots of lube. I almost had it out and then snap, the glass broke. My original question was whether or not anyone had any luck replacing it.
I am going to give it some thought and see what is out there. Maybe a high quality plastic mirror would work. Thank you for your responses. |
Mikey914 |
Nov 16 2020, 09:34 AM
It could work. We used acrylic mirror that was treated with anti abrasion coating (Used in aviation applications
) otherwise it will scratch easily. No one could figure out how we were able to sew the mirrors into the visors we made without cracking of breaking them. Now you know |
Lo-Fi Version | Time is now: 14th May 2024 - 09:45 AM |
