V8 Engine |
V8 Engine |
pjhaun |
Jul 15 2005, 02:40 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Can anybody tell me if a stroker engine consumes more gas than a none stroked engine?
Thank You!!!!!!! |
Andyrew |
Jul 15 2005, 02:42 PM
Depends how you drive it.
asside from that.. I dont know! |
messix |
Jul 15 2005, 03:49 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
generally if the displacement is the same there wont be much if any difference.
ideally an over square engine [ stroke is longer than the bore dia.] will be more fuel efficient than a under square engine [ stroke shorter than bore dia.] for the same displacement. this subject can get very deep in engineering speak and thermodynamic theory. do you wanna open this can of worms? (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Mueller |
Jul 15 2005, 03:51 PM
bored with your V6??? |
chunger |
Jul 15 2005, 03:57 PM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
I'm bored with my jackstands. . . (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
pjhaun |
Jul 15 2005, 04:25 PM
Mueller: I found out that TA Performance in Scottsdale, AZ. has a storker kit for the Buick v6. And believe it or not they make a Buick v6 aluminum block. They said it weights about 200 lbs. They even make aluminum heads. The v6 aluminum block goes up to 4.00 bore size. The guy I talk to said that these engines can put out over 900 HP with twin turbos. I thought it be would cool to have an aluminum v6 that would put out 300 HP and only weight about 280 lbs. |
914GT |
Jul 15 2005, 04:51 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
A 'stroker' engine may or may not use more gas than a 'non-stroker' engine. Depends on how you are trying to define things. A 383 stroker has less displacement than a 'non-stroked' stock displacement 400, or big block 396, 427, or 454. So in that case it might use less gas if everything else (cams, head, etc.) was the same (which in the real world it won't be). But if you are comparing a 383 which has been stroked from a 350 than obviously its displacement is larger and it will have more torque and power, and probably use more gas in the process. |
Mueller |
Jul 15 2005, 04:55 PM
sounds neat and expensive...and I like it !!!!! |
Lo-Fi Version | Time is now: 20th May 2024 - 07:01 AM |
