What am I looking at here, transmission question |
zprovo |
Nov 16 2020, 04:55 PM
Newbie Group: Members Posts: 19 Joined: 16-September 20 From: Nashville TN Member No.: 24,697 Region Association: South East States |
hcdmueller |
Nov 16 2020, 04:58 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
Your transmission was either converted to a side shift and they didn't replace the tail shift nose cone, or the side shift cone was replaced with a tail shift version due to some sort of damage.
brant |
Nov 16 2020, 04:59 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
It looks like a tail shift transmission that was converted to Side shift
however they did not change out the rear tail cover when they did this so the disconnected linkage is the old linkage that is likely not connected internally in any way does it wiggle loose... when you turn the tail input shaft by hand? |
zprovo |
Nov 16 2020, 05:10 PM
It looks like a tail shift transmission that was converted to Side shift however they did not change out the rear tail cover when they did this so the disconnected linkage is the old linkage that is likely not connected internally in any way does it wiggle loose... when you turn the tail input shaft by hand? Interesting. It doesn't budge by hand (I didn't put a tool on it). Thanks for the info! |
brant |
Nov 16 2020, 05:11 PM
It could of been a damaged rear tail cone.
but if your car is a 1971 then someone updated it to side shifter and didn't bother to change out the tail you can buy a SS tail for it and easily change it in the car or not.... |
zprovo |
Nov 16 2020, 05:24 PM
rhodyguy |
Nov 17 2020, 02:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That area above the plate on the bottom of the cover is loaded with gear lube. Looks like an attempt to stop a leak was done with RTV. There is a correct gasket for that task. The cover may be distorted too.
Al Meredith |
Nov 17 2020, 02:48 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
What I have done when I convert a Tail shifter to a side shifter and don't have a rear side shifter case I don't install the tail internal linkage and seal the long tail linkage holder with some JB weld and a freeze plug.
Lo-Fi Version | Time is now: 20th May 2024 - 03:11 PM |
