FS: Early Back pads, koni fronts, gt eng lid, Fuchs 16" |
Mike D. |
Nov 19 2020, 01:10 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Early back pads, one with seat, tell me which one you want. GT Engine lid, needs your back grate and letters $100 Springs, stock set $25 Springs, aftermarket, heavy, not sure rate and narrower than stock $80 -no curb rash on either set, let me know with or without tires, ask in PM 911 3.2 complete exhaust FOR USE IN 911 $800 911 Engine mount FOR USE IN 911 $50 911 3.2 engine tins, missing one piece FOR USE IN 911 $80 Send PM with questions and for more pics if needed All prices plus shipping. ALL shipping cost. Attached thumbnail(s) Attached image(s) |
Mike D. |
Nov 19 2020, 01:11 AM
pics
Attached thumbnail(s) |
Mike D. |
Nov 19 2020, 01:13 AM
Wheels Sold
Mike D. |
Nov 19 2020, 01:14 AM
pics - 911 exhaust gone
Mike D. |
Nov 19 2020, 01:16 AM
914 Bus Mufflers sold
sfspeed |
Nov 19 2020, 08:20 AM
Newbie Group: Members Posts: 9 Joined: 26-April 20 From: SF Member No.: 24,184 Region Association: Northern California |
Need black back pad. Pm sent
Tdskip |
Nov 19 2020, 10:04 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Mike - just to be clear the 911 engine mount and exhaust set up are for a 3.2 as fitted to a 911 rather than to fit a 3.2 to a 914, correct?
mb911 |
Nov 19 2020, 11:00 AM
914 Guru Group: Members Posts: 6,814 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
bob164 |
Nov 19 2020, 11:50 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Mike,
I will take the Konis and early back pads, the one with the grey seat inserts. Check your PMs. Bob |
Mike D. |
Nov 19 2020, 12:12 PM
Mike - just to be clear the 911 engine mount and exhaust set up are for a 3.2 as fitted to a 911 rather than to fit a 3.2 to a 914, correct? Yes, they were left overs from 914-6 conversion. I just posted here with everything else just in case someone was interested. Maybe I should remove them to avoid confusion... |
Tdskip |
Nov 19 2020, 12:18 PM
Mike - just to be clear the 911 engine mount and exhaust set up are for a 3.2 as fitted to a 911 rather than to fit a 3.2 to a 914, correct? Yes, they were left overs from 914-6 conversion. I just posted here with everything else just in case someone was interested. Maybe I should remove them to avoid confusion... No worries on leaving them, I would, just thought making it clear what they are good for was worthwhile. Good luck with these bits, someone will want them. |
Lo-Fi Version | Time is now: 27th April 2024 - 04:55 PM |
