Car dolly recoomendation? |
JeffBowlsby |
Nov 20 2020, 11:59 AM
914 Wiring Harnesses Group: Members Posts: 8,478 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Thinking about getting a set of wheel dollies.
I had some HF cheapos awhile back, they worked but had cast iron wheels and left scratches on the garage floor. Have seen some with what look like a rubber wheel but concerned they might flat spot. Interested in something simple and low tech, but well built and roll around easy. Not interested in the fancy ones with onboard hydraulics. |
porsha916 |
Nov 23 2020, 11:49 AM
Member Group: Members Posts: 214 Joined: 1-June 04 From: Greenwood, SC Member No.: 2,137 Region Association: None |
914043 |
Dec 10 2020, 11:10 PM
Member Group: Members Posts: 87 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
porsha916 |
Mar 16 2021, 07:28 AM
these work just as good as the more expensive metal ones. cost $7.99 each support 1000lbs per wheel and can still be used to move furniture with ease. when I am changing an engine I remove chock and put it on top of two cement blocks to keep car from rolling off. Be careful when lifting sides of 914 with floor jack and 2x6 , because the floor jack moves when lifting and can tip the cement blocks !!! |
Lo-Fi Version | Time is now: 25th April 2024 - 07:21 PM |
