> Won’t start, After driving
Ebradley
post Nov 20 2020, 01:50 PM
Hi all
I recently drove my 74 Porsche 914 2.0 on a hot day and the car would not start after driving. I thought maybe vapor Lock. Drove it yesterday and it was 78degrees and the same thing happened. Normally drives amazing. After driving, stalled at the traffic light. Then would just turn over but no start. Do you think it’s vapor lock? After 15min it started up and I was on my way
Thanks for the advice
Replies(1 - 6)
ctc911ctc
post Nov 20 2020, 03:54 PM
Start with the easy stuff.
Engine Temp Sensor is where I would start.
Also:
https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot
Report back with more details, we will solve this with you,
QUOTE(Ebradley @ Nov 20 2020, 02:50 PM) *
Hi all
Lg914
post Nov 20 2020, 04:33 PM
It sounds like it could be the fuel filter. After a bit of sitting, enough fuel seeps trough to get it running for a bit till it staves out.
JamesM
post Nov 20 2020, 06:21 PM
Is it still fuel injected?
Where is the fuel pump in the front or the rear?
Ebradley
post Nov 21 2020, 12:25 AM
Yes, original fuel injection. Fuel pump in stock location. Car gas 109,000 original miles
ClayPerrine
post Nov 21 2020, 05:30 AM
That does sound like the typical symptoms of vapor lock.
Hook a fuel pressure gauge to it and verify it is loosing fuel pressure when the problem happens.
The fix is to move the pump up front. If you do move it, then replace the fuel lines with a set of the stainless steel Tangerine lines. The old plastic lines have been known to fail and cause engine fires.
Tdskip
post Nov 21 2020, 07:05 AM
If that happens again try flooring it to see if it will catch, same thing happened in my Saab 99 which uses the same system.
Not a fix, but might get you back and running faster.
- Lo-Fi Version Time is now: 12th July 2025 - 02:16 AM
