Yellow top injectors |
914nb |
Nov 22 2020, 08:12 AM
Newbie Group: Members Posts: 34 Joined: 5-August 20 From: Northamptonshire, UK. Member No.: 24,569 Region Association: England |
Hi all,
Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan |
bdstone914 |
Nov 22 2020, 09:51 AM
bdstone914 Group: Members Posts: 4,518 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi all, Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan That should work. Operating pressure is 32psi. They should handle 60 for test purposes. |
914nb |
Nov 22 2020, 10:01 AM
[quote name='bdstone914' date='Nov 22 2020, 09:51 AM' post='2868443']
[quote name='914nb' post='2868428' date='Nov 22 2020, 08:12 AM'] Hi all, Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan [/quote] That should work. Operating pressure is 32psi. They should handle 60 for test purposes. Thanks for clarification, unfortunately I have all 4 injectors leaking, not something I was expecting when the previous owner had the injectors rebuilt and only had around a thousand miles on them. Just found the starter is seized solid too! After some work I had it firing out but the motor won't turn |
Nov 22 2020, 11:06 AM
914-6 GT in waiting Group: Members Posts: 19,262 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
We were pushing the car a bit with the gear engaged so I'm sure the engine tuns over. Are you sure the injectors are leaking and not a hose or seal? It would be really odd to have all 4 leak from a set that didn't leak before. I thought when the driver side was leaking it was a hose or seal that wasn't seated or clamped tightly.
914nb |
Nov 22 2020, 11:10 AM
We were pushing the car a bit with the gear engaged so I'm sure the engine tuns over. Are you sure the injectors are leaking and not a hose or seal? It would be really odd to have all 4 leak from a set that didn't leak before. I thought when the driver side was leaking it was a hose or seal that wasn't seated or clamped tightly. I will pop you a video mark so you can see what I mean. |
Lo-Fi Version | Time is now: 12th May 2024 - 03:05 PM |
