914nb
Nov 22 2020, 08:12 AM
Hi all,
Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner.
Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing?
Thanks
Nathan
bdstone914
Nov 22 2020, 09:51 AM
QUOTE(914nb @ Nov 22 2020, 08:12 AM)
Hi all,
Thanks
Nathan
That should work. Operating pressure is 32psi. They should handle 60 for test purposes.
914nb
Nov 22 2020, 10:01 AM
[quote name='bdstone914' date='Nov 22 2020, 09:51 AM' post='2868443']
[quote name='914nb' post='2868428' date='Nov 22 2020, 08:12 AM']
Hi all,
Thanks
Nathan
[/quote]
Thanks for clarification, unfortunately I have all 4 injectors leaking, not something I was expecting when the previous owner had the injectors rebuilt and only had around a thousand miles on them.
Just found the starter is seized solid too! After some work I had it firing out but the motor won't turn
Nov 22 2020, 11:06 AM
We were pushing the car a bit with the gear engaged so I'm sure the engine tuns over. Are you sure the injectors are leaking and not a hose or seal? It would be really odd to have all 4 leak from a set that didn't leak before. I thought when the driver side was leaking it was a hose or seal that wasn't seated or clamped tightly.
914nb
Nov 22 2020, 11:10 AM
QUOTE(mepstein @ Nov 22 2020, 11:06 AM)
I will pop you a video mark so you can see what I mean.
