Oil Catch Can? |
Oil Catch Can? |
RolinkHaus |
Nov 22 2020, 02:51 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
I’ve got the engine out and just curious if an oil catch can is worth it? What does an oil catch can do to the cooling properties? Good possibility I will track the car in the future.
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Dion |
Nov 22 2020, 08:19 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
@RolinkHaus you might pose this question in the Paddock for in depth answers. I’ll be running one on my six when done. I’m still learning but as I understand it ,the tank and motor need to be vented and vapors will be collected. Others more knowledgeable will respond. Good luck with the project.
Steve |
Nov 23 2020, 10:03 AM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Do a search lots of options for “catch can”!! On a stock six they dump the oil back in the motor via the intake. If you over fill the oil tank, you will have quite the smoke storm on startup!!. Otherwise it is normal to get “blow by” which either ends up back in the motor or in a catch can. Also makes a big mess if your running carbs. This is why most people use a catch can. Has nothing to do with making the motor run cool.
rgalla9146 |
Nov 23 2020, 10:34 AM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Carbed 6 ? Cheap, easy, invisible and cleanable.
No modification to hoses for stock 6 air filter housing. Attached thumbnail(s) |
RolinkHaus |
Nov 23 2020, 10:42 AM
Thanks for the insight
Lo-Fi Version | Time is now: 10th May 2024 - 05:33 AM |
