What 'obvious' 914 thing did you not know?, I was a 914 owner for X number of years before I found out..... |
ClayPerrine |
Nov 25 2020, 08:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just saw this thread http://www.914world.com/bbs2/index.php?showtopic=350102 about how to open the engine lid. It got me to thinking about things that "everyone knows" about our beloved little cars that was not glaringly obvious to me when I was a new owner.
So.. post your list of items that say "I was a 914 owner for X number of years before I found out....." Think of this as helping to educate new 914 owners. I will start it off: I was a 914 owner for 5 years before I found out that the left and right outer door handles are different. |
FRUNKenstein |
Dec 14 2020, 03:33 PM
Member Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest |
I didn't know for 5 months that the turn signal indicator in the instrument cluster will blink one time and then go out if you have a bulb not working in the turn signal. The indicator would work as normal on left turns, but on right turns it would blink once, then never blink again. On most cars, the blinker speeds up if a bulb is out, but the blink rate remained the same. Turned out to be the front right bulb wasn't connecting properly. Once I adjusted the contacts and sprayed a little Deoxit in there, the signal worked and the indicator on the dash kept blinking as long as the turn signal was on.
Lo-Fi Version | Time is now: 8th May 2024 - 09:49 PM |
