sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
ghjghj
Attached image(s) ![]() |
sean_v8_914 |
ghjgh
sean_v8_914 |
gfhtr
sean_v8_914 |
the engine IS a T-Type Buick with the skip fire ingnition. they rev rough. why would Buick put a turbo on these? teh Grand National had teh smooth firing v6 with FI
sean_v8_914 |
its a V8 ignition with 2 plugs deleted. note teh gap in teh Dizzy cap
sean_v8_914 |
pull thru turbo carb
sean_v8_914 |
needs an expansion tank in teh cooling system
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
be careful, check engine type and serial numbers...
there are MANY plausible, satisfactory explanations of what could have been done; make sure you get one... interesting that he'll sell the engine to a 'wining' bidder - as opposed to a 'winning' bidder... so i guess you gotta grovel too... Attached image(s) ![]() |
sean_v8_914 |
901 106 101 5r
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
ArtechnikA |
that's just the casting number of the alternator shroud. the engine serial number and Type Number are found on the right side of the case in the area of the crankshaft pulley. the '901' number on the side of the case is the engine case casting number, and similarly not unique. |
Lo-Fi Version | Time is now: 13th July 2025 - 08:41 PM |
