Turn key, battery goes flat, ignition switch smoky. |
jaredmcginness |
Nov 30 2020, 08:25 PM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Me again.
It’s gonna be one problem post a day, until next years Octeener fest. (IMG:style_emoticons/default/idea.gif) So close here to firing this motor (in the car)(works fine outside of it) I’m thinking I have a short somewhere in the ignition, but everything seems to check out. Notes: Early car, early VW style switch. (After market) Turn key, ACC works fine, fuel pump relay clicks, all electrics work. 12v to coil, 12v to starter, power supply relay is good. Turn key to run, Nothing - power goes flat, as long as I hold the key down. Messing around a bit, tried again and the ignition switch/column starts smoking and the IGNS wires are warm. I believe once she smokes she’s done. I’ll buy a new switch tomorrow, but I’m trying to probe if this sounds like more than a switch. All my wiring matches the bowlsby pages. Battery is new. Switch was new (but probably Taiwan crap), new ground to battery and new ground strap. Cleaned every ground I can find. Does not even considering the idea of cranking. Starter cranks fine when manually jumped. Now that my smoke is out, queue the ‘Replacement Can’ comments. (IMG:style_emoticons/default/bye1.gif) |
Spoke |
Nov 30 2020, 09:07 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Early car, early VW style switch. (After market) Turn key, ACC works fine, fuel pump relay clicks, all electrics work. 12v to coil, 12v to starter, power supply relay is good. I believe there are only 3 positions for the ignition switch: Off; Running; and Start. So when you "Turn key", this is to the Running position, correct? The 12V to the starter is measured on the large wire from the battery, correct? 12V on the large wire is constant regardless of the key position. The smaller yellow wire comes from the ignition key when in the "Start" position and puts 12V on the yellow wire to the bendix on the starter. QUOTE Turn key to run, Nothing - power goes flat, as long as I hold the key down. Messing around a bit, tried again and the ignition switch/column starts smoking and the IGNS wires are warm. You mean when you go to the "Start" position, correct? In the Start position the yellow wire on the starter should be powered. This wire goes from the ignition switch to the relay board then to the starter. Try disconnecting the harness on the relay board from the cabin and see if the power goes flat. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:29 PM |
