cv axles, -how much cv joint play is acceptable? |
MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
pete000 |
Dec 3 2020, 10:10 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
MM1 |
Dec 4 2020, 09:31 AM
Regarding non-914 cv joints - since there's no machined recess for the gasket, wouldn't I need to use a sealant? And doesn't that increase the risk of grease leakage/joint failure? |
914_teener |
Dec 4 2020, 10:26 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Regarding non-914 cv joints - since there's no machined recess for the gasket, wouldn't I need to use a sealant? And doesn't that increase the risk of grease leakage/joint failure? Leakage yes....failure probably not. It'll just splatter some grease up on the body. Think of it as rust repllelant. Like PMB states though....don't use the gaskets unless there is a recess for them. Plenty of threads on this. |
MM1 |
Dec 4 2020, 10:45 AM
Regarding non-914 cv joints - since there's no machined recess for the gasket, wouldn't I need to use a sealant? And doesn't that increase the risk of grease leakage/joint failure? Leakage yes....failure probably not. It'll just splatter some grease up on the body. Think of it as rust repllelant. (IMG:style_emoticons/default/av-943.gif) Like PMB states though....don't use the gaskets unless there is a recess for them. Plenty of threads on this. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:35 PM |
