cv axles, -how much cv joint play is acceptable? |
MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
914werke |
Dec 5 2020, 02:03 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) Only there is no provision on the stub axle's or output flanges for 6 bolts... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 06:18 AM |
