cv axles, -how much cv joint play is acceptable? |
MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
76-914 |
Dec 4 2020, 11:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif)
MM1 |
Dec 5 2020, 11:23 AM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) What's the word on cv's from PMB coming in January? How will they be different from the GKN/Loebro machined for gasket version that Eric sells now? |
Lo-Fi Version | Time is now: 15th May 2024 - 06:52 PM |
