cv axles, -how much cv joint play is acceptable? |
MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
MM1 |
Dec 7 2020, 01:54 AM
Is it ok to use lubro-moly cv grease for the front wheel bearings?
Or do you all prefer something else? |
Lo-Fi Version | Time is now: 15th May 2024 - 02:41 AM |
