cv axles, -how much cv joint play is acceptable? |
MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
76-914 |
Dec 4 2020, 11:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif)
bkrantz |
Dec 5 2020, 08:34 PM
914 Guru Group: Members Posts: 7,762 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) I am still not home to confirm, but here is the listing at Pelican. They specify this CV is for the 914-4. https://www.pelicanparts.com/More_Info/9143...&DID=168624 |
bbrock |
Dec 5 2020, 10:37 PM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) I am still not home to confirm, but here is the listing at Pelican. They specify this CV is for the 914-4. https://www.pelicanparts.com/More_Info/9143...&DID=168624 Well that's interesting. Keeping fingers crossed for what you find. (IMG:style_emoticons/default/popcorn[1].gif) |
bkrantz |
Dec 10 2020, 09:25 PM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) I am still not home to confirm, but here is the listing at Pelican. They specify this CV is for the 914-4. https://www.pelicanparts.com/More_Info/9143...&DID=168624 Well that's interesting. Keeping fingers crossed for what you find. (IMG:style_emoticons/default/popcorn[1].gif) Not good news. Although the boxes are marked with 914-4 and part number 914 332 029 03 (which should be correct for 914-4) the CV inner has 25 splines, not the required 33 splines. I contacted Pelican and they are checking with the supplier (which was supposed to be Porsche). The CVs I got are GKN. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:21 AM |
