6 conversion throttle linkage - cable type |
IronHillRestorations |
Dec 3 2020, 02:22 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've got a car in the shop that I'm finishing a 6 conversion on.
I seem to remember someone here making a cable type throttle linkage. I've used Rich Johnson's before, and have a kit here, but looking for an easier way. Thanks in advance! |
Mark Henry |
Dec 4 2020, 11:37 AM
The whole logic of the carb stock(-ish) linkage is to keep the cable in as straight line as possible. Once you start making the cable turn tight corners is when you start into binding issues.
Root_Werks |
Dec 7 2020, 11:20 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The whole logic of the carb stock(-ish) linkage is to keep the cable in as straight line as possible. Once you start making the cable turn tight corners is when you start into binding issues. (IMG:style_emoticons/default/agree.gif) There are reasons the factory had a bell crank. My 2.7 CIS comes up using a 4-cyl cable. It routes very similar to any L-Jet or D-Jet, but I might still swap it for a bell crank system. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:06 PM |
