NOS axle install, plug and play or refresh the grease? |
bbrock |
Dec 4 2020, 08:49 AM
@914_7T3 set me up with a very nice NOS rear axle for my build that I'm finally getting ready to install. It looks like it has been sitting on a shelf for a very long time but the ends are wrapped in plastic to keep them clean. I'm curious of opinions on whether I should just bolt it on or clean and re-grease first. Thanks.
horizontally-opposed |
Dec 4 2020, 08:54 AM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
@914_7T3 set me up with a very nice NOS rear axle for my build that I'm finally getting ready to install. It looks like it has been sitting on a shelf for a very long time but the ends are wrapped in plastic to keep them clean. I'm curious of opinions on whether I should just bolt it on or clean and re-grease first. Thanks. Will be curious to see what others say, but I'd clean and repack on the idea that a) lubricants tend to degrade over time, b) grease now is probably better than whatever grease is in there, and c) it'll never be easier than now. Do they have new roll pins in them? I once made the mistake of installing an axle without roll pins in my youth. The result wasn't pretty… |
bbrock |
Dec 4 2020, 09:04 AM
Do they have new roll pins in them? I once made the mistake of installing an axle without roll pins in my youth. The result wasn't pretty… Haven't even looked so thanks for the reminder. Another question I should have added to the OP. I have Swepco and Redline CV-2 on hand which are both premium high temp greases. Anyone have a preference for CVs? I'm leaning toward Redline because it is full synthetic and the red color is pretty. (IMG:style_emoticons/default/smile.gif) |
914Sixer |
Dec 4 2020, 10:01 AM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No telling how old the grease is so it might be best to repack them.
914_teener |
Dec 4 2020, 10:24 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Inspect and repack.
MM1 |
Dec 4 2020, 10:53 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Do they have new roll pins in them? I once made the mistake of installing an axle without roll pins in my youth. The result wasn't pretty… Haven't even looked so thanks for the reminder. Another question I should have added to the OP. I have Swepco and Redline CV-2 on hand which are both premium high temp greases. Anyone have a preference for CVs? I'm leaning toward Redline because it is full synthetic and the red color is pretty. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) Curious what the consensus is . . .just bought 4 of these from PMB - shot in the dark for me: |
SteveL |
Dec 4 2020, 10:58 AM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Repack. Off the shelf you are not certain what you have for grease. Repacked you are certain.
914Sixer |
Dec 4 2020, 04:55 PM
Lubro Moly is what I use.
bbrock |
Dec 4 2020, 04:56 PM
What??!!! Do we have a unanimous consensus? Is The World broken? This never happens. (IMG:style_emoticons/default/av-943.gif)
Thanks all. Repacking was my leaning also but wanted to make sure there wasn't some magic elixir in the factory grease that could never be replaced. I need to repack the joints on the other axle anyway so not much extra work. Any opinions on Swepco vs Redline CV-2? Thanks again. |
Superhawk996 |
Dec 4 2020, 05:40 PM
914 Guru Group: Members Posts: 5,782 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
What??!!! Do we have a unanimous consensus? Is The World broken? This never happens. (IMG:style_emoticons/default/av-943.gif) Thanks all. Repacking was my leaning also but wanted to make sure there wasn't some magic elixir in the factory grease that could never be replaced. Magic Elixer is expensive - sure you want it? (IMG:style_emoticons/default/happy11.gif) OK - Joking ONLY -- would not be appropriate for CV's. Again -- Not Serious before everyone gets wound up. |
Amphicar770 |
Dec 4 2020, 05:43 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Repacking is cheap insurance. No down side to doing so, potential upside.
MM1 |
Dec 4 2020, 06:47 PM
What??!!! Do we have a unanimous consensus? Is The World broken? This never happens. (IMG:style_emoticons/default/av-943.gif) Thanks all. Repacking was my leaning also but wanted to make sure there wasn't some magic elixir in the factory grease that could never be replaced. Magic Elixer is expensive - sure you want it? (IMG:style_emoticons/default/happy11.gif) Boy I hope you're right about these, @Superhawk996 , for what I just paid for this ambrosia - I could have had Tarrett axles . . .well, at least one. (IMG:style_emoticons/default/lol-2.gif) |
bbrock |
Dec 5 2020, 06:21 PM
Well, job done. I remembered that being a fun job but had forgotten just HOW fun. My curse generator over heated three times so I had to pause to let it cool down. The whole time I kept thinking you guys had somehow conspired with your advice just to ruin my day, but I confess it was pretty obvious the old grease was getting waxy and needed to be replaced. Now I have the other side to do - YIPEE (IMG:style_emoticons/default/cheer.gif) At least those are already cleaned. That's 3/4 of the job.
Thanks all for your advice. Hope your days went better than mine but it is nice to have it out of the way. (IMG:style_emoticons/default/beerchug.gif) |
altitude411 |
Dec 5 2020, 06:58 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
My curse generator over heated three times so I had to pause to let it cool down. In case you over used your supply and need to refresh... (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 08:11 PM |
