| iankarr |
Dec 5 2020, 07:24 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,582 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Is it possibled your clutch tube has broken free? Are you able to tighten the cable and have it stay tight?
| JOEPROPER |
Dec 5 2020, 07:48 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
Make sure you exhaust every possible way to disengage the clutch. You may need to use a pry bar against the clutch fork to make sure the clutch is disengaged. Be careful!!
| rgalla9146 |
Dec 5 2020, 09:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,887 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I think the key is this statement in the original post. "Clutch was never separated from the pressure plate." If the pressure plate is removed, the clutch disc will fall out. It does not attach to the pressure plate. I think one of his pictures also showed the disc firmly 'stuck' to it. Pull the engine or trans, remove the pressure plate and separate the disc. Yes, the second sentence here is probably the key The PP and disc were 'attached' ? ....never seperated ? and the trans slid right on............no clutch alignment tool ? or tool slid right in ? the disc is likely 'bonded' to the PP |
| Steve |
Dec 5 2020, 11:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,982 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
It definitely sounds like a clutch problem. If you do take it apart, check the part numbers on the disk and pressure plate. Some clown sold me mismatched parts and I had the same problem. 911T/914-4 2.0 pressure plate and 911S disk.
| mlindner |
Dec 5 2020, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,717 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Borrow a large pipe bar clamp, clamp from fork to back of clutch cable wheel housing. screw clamp to pull fork back releasing pressure plate to disk.
| jaredmcginness |
Dec 5 2020, 03:50 PM
... ![]() ![]() ![]() Group: Members Posts: 509 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
Before removing the trans remove the starter. Prop the pedal against the floor. Rotate the flywheel so that you can reach through spaces in the pressure plate to push or pull on the disc. Good luck. Rory Rory, you glorious SOB! @rgalla9146 I followed this. Pulled starter, pry bar to turn fly wheel, inserted bar into each of the 6 different spaces to evenly apply pressure against the clutch. On the 6th pry, the clutch broke free. All in all this took about 20 minutes. I realigned the shifter. Put it on the ground and it goes into every gear like it has been waiting to! You guys are the best! Thanks for all this advice!!! |
| rgalla9146 |
Dec 5 2020, 05:15 PM
Glorious SOB is correct but credit goes to all who provided input. Between your last name, my first name and an Irish green car how could we miss ? Great result. |
| type2man |
Dec 5 2020, 06:43 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I have had this issue a few times. Here is what I do. I start the car in first gear with the clutch pressed and then rev it a few times and it breaks free.
Lo-Fi Version | Time is now: 7th December 2025 - 05:15 AM |
