How fast is fast enough – Turbocharging the LS, Screamsicle gets a Turbo |
dan10101 |
Dec 5 2020, 02:27 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Yeah, I know its nuts. But we’re going to turbo the Screamsicle. (also known as Morpheus..)
For you that aren’t familiar with the car, it’s a 5.7 LS6 engine that has many goodies. The dyno sheet I was given with the car shows 430 rwhp. My dyno showed 362 rwhp. But I’m thinking that was mostly the differences in dynos. Either way, both numbers are thrown around. We’ll go with 362 going forward. We’ll be adding a VS Racing 7875 Turbo with .96ar and V-band connections. With minimum boost I expect to be close to 500rwhp. We’ll use that for AX and track days at least to start. The drag strip is where we’ll eventually turn it up to about 14psi. That will give us approx. 700rwhp and hopefully set a mark to be beat. I go into why and everything else in the video, but really, it’s because I want to… Here’s the intro video for the LS Turbo series on our Budget Outlaws channel. https://youtu.be/6_Mlwf0nHLw |
AZBanks |
Dec 5 2020, 04:25 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower.
— Mark Donohue |
wndsrfr |
Dec 5 2020, 08:40 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Go with Wilwood calipers & rotors--the ones I have are 4 piston using Porterfield pads meant for stock cars--like way too much brakes for my 1950 pounds & 215 hp. Search on my name and wilwood for description of the specific calipers/rotors--BTW, rotors are like $40 each--hard to beat! For drag use go with Porterfield's pads that have strong bite without needing to be hot...
dan10101 |
Dec 5 2020, 09:12 PM
Go with Wilwood calipers & rotors--the ones I have are 4 piston using Porterfield pads meant for stock cars--like way too much brakes for my 1950 pounds & 215 hp. Search on my name and wilwood for description of the specific calipers/rotors--BTW, rotors are like $40 each--hard to beat! For drag use go with Porterfield's pads that have strong bite without needing to be hot... I'll check it out. I already have 930 brakes all around, So they should work, but somethings not right with the balance. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:45 AM |
