How fast is fast enough – Turbocharging the LS, Screamsicle gets a Turbo |
dan10101 |
Dec 5 2020, 02:27 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Yeah, I know its nuts. But we’re going to turbo the Screamsicle. (also known as Morpheus..)
For you that aren’t familiar with the car, it’s a 5.7 LS6 engine that has many goodies. The dyno sheet I was given with the car shows 430 rwhp. My dyno showed 362 rwhp. But I’m thinking that was mostly the differences in dynos. Either way, both numbers are thrown around. We’ll go with 362 going forward. We’ll be adding a VS Racing 7875 Turbo with .96ar and V-band connections. With minimum boost I expect to be close to 500rwhp. We’ll use that for AX and track days at least to start. The drag strip is where we’ll eventually turn it up to about 14psi. That will give us approx. 700rwhp and hopefully set a mark to be beat. I go into why and everything else in the video, but really, it’s because I want to… Here’s the intro video for the LS Turbo series on our Budget Outlaws channel. https://youtu.be/6_Mlwf0nHLw |
dan10101 |
Feb 20 2021, 01:25 PM
We're getting closer...
I made some progress on the plumbing, the hot side, and the cold side Things to do: Plumb the Oil Scavenging Pump for the turbo oil drain. Install the 3bar map sensor. (just in case I ever want to run 15psi...) (IMG:style_emoticons/default/aktion035.gif) Update the ECU to work with the 3bar. And do a home brew tune to get it ready for a bit of boost. (ok I probably should have stuck with 2bar...) Fab up some covers for the bottom and the top. And some wiring... A couple of new videos... Somewhat entertaining if only for a laugh... Aluminum welding is hard... https://www.youtube.com/watch?v=vuEdYdt-DPY I hacked together an exhaust insert. It actually kinda works. I'll do some sound comparison in the latest video. Plus added the missing wastegate. https://www.youtube.com/watch?v=0fwkngUXIdI...eature=youtu.be |
Lo-Fi Version | Time is now: 26th May 2024 - 11:59 PM |
