How fast is fast enough – Turbocharging the LS, Screamsicle gets a Turbo |
burton73 |
Dec 7 2020, 11:25 AM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Great question and I think there is a simple answer. Fast enough is when it breaks, and on the street the more hp, the more wheel spin, or something has to give. So I guess the answer is there is a limit to no limits. LOL Twin Turbo LS you have to get the gearbox from the C8. (IMG:style_emoticons/default/beerchug.gif) He has a 4 speed gearbox from a 930 Porsche. Good for over 650HP so that should not break -930 CVs? Bob B |
dan10101 |
Dec 7 2020, 12:11 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Great question and I think there is a simple answer. Fast enough is when it breaks, and on the street the more hp, the more wheel spin, or something has to give. So I guess the answer is there is a limit to no limits. LOL Twin Turbo LS you have to get the gearbox from the C8. (IMG:style_emoticons/default/beerchug.gif) He has a 4 speed gearbox from a 930 Porsche. Good for over 650HP so that should not break -930 CVs? Bob B Yes, 930 CVs. The wide range 4spd means less shifting. 60-100 and maybe even 30-100 times could be done without shifting if I have the gearing right. So that may be where I have my most fun if I'm allowed. (IMG:style_emoticons/default/shades.gif) Can someone confirm my gear ratios? I believe it's a 78 930 box. Diff 4.22 1st 2.25 2nd 1.304 3rd .893 4th .625 |
sixnotfour |
Dec 7 2020, 12:45 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
930/34
930 Turbo 1978-85 4-speed fully-synchronized transaxle Manufactured by Porsche (ZF) Long bell housing Plate-type limited-slip differential available Rod shift Single-plate clutch Gear ratios: 1st gear: 2.25 2nd gear: 1.304 3rd gear: 0.893 4th gear: 0.625 Ring and pinion: 4.22 |
burton73 |
Dec 7 2020, 12:54 PM
I have a short bell housing on mine, does that make it a 1977?
Bob B . |
dan10101 |
Dec 7 2020, 01:01 PM
dan10101 |
Dec 7 2020, 01:08 PM
Well, according to this website. I have an earlier trans. 75-77
And lower diff gears. https://californiamotorsports.net/pages/por...e-specification I don't know if that will matter at all, but just trying to keep it straight. |
dan10101 |
Dec 7 2020, 01:14 PM
Actually Bobby Hart from CA Motorsports rebuilt it last.
I'm guessing he would discourage a turbo setup. (IMG:style_emoticons/default/sunglasses.gif) |
burton73 |
Dec 7 2020, 01:15 PM
sixnotfour |
Dec 7 2020, 01:27 PM
https://www.gboxweb.com/930specs.html
930/30 930 Turbo 1975-76 4-speed fully-synchronized transaxle Manufactured by Porsche (ZF) Short bell housing Plate-type limited-slip differential available Rod shift Single-plate clutch Gear ratios: 1st gear: 2.25 2nd gear: 1.304 3rd gear: 0.893 4th gear: 0.656 Ring and pinion: 4.22 |
dan10101 |
Dec 7 2020, 01:34 PM
Mine is set up to run upside down and has oil squirter set up for the trans to run with an oil cooler or not. The place that built it GBox said I would not need to run it but it is set up for it. Bob B Yeah, Michael Cuoco on the Facebook group is setup that way. I'm guessing when they built my car, they weren't sure if it would oil correctly in that orientation. Now you guys can save the bucks to flip it internally. His looks to be the later case. I'm thinking mine has the later gear ratio. 4.22. The gearing doesn't seem to add up. Maybe my speedo is off. I'll have to do some testing. Here is Michaels |
dan10101 |
Dec 7 2020, 01:36 PM
Thank You. That makes more sense. |
AZBanks |
Dec 7 2020, 02:06 PM
Senior Member Group: Members Posts: 1,060 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
I have one of these kits in my garage, still in boxes. Too bad it is for an LT, not an LS.
https://www.bankspowerproducts.com/Banks-Po...tem-p/21103.htm |
dan10101 |
Dec 7 2020, 02:15 PM
I have one of these kits in my garage, still in boxes. Too bad it is for an LT, not an LS. https://www.bankspowerproducts.com/Banks-Po...tem-p/21103.htm There I fixed it for you. Can't go wrong with Banks. And you could probably sell the Banks headers for more that the ebay headers. |
tygaboy |
Dec 7 2020, 02:29 PM
914 Guru Group: Members Posts: 5,286 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Dan - I'm running a set of eBay turbo forward headers and I have to say, for $160, they are actually pretty nice. I wouldn't hesitate to recommend them, if that's the sort of set up you need.
sixnotfour |
Dec 7 2020, 02:41 PM
Way Back 1986
rhodyguy |
Dec 7 2020, 03:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That looks like the engine comp might get a little warm. Even with the heat shielding.
Andyrew |
Dec 7 2020, 03:28 PM
Hey all, voice of reason over here.. He's going with ONE ~1000hp turbo mounted by the passenger headlight, not two (IMG:style_emoticons/default/smile.gif)
Andyrew |
Dec 7 2020, 03:30 PM
sixnotfour |
Dec 7 2020, 03:42 PM
QUOTE Hey all, voice of reason over here.. He's going with ONE ~1000hp turbo mounted by the passenger headlight, not two That's how kids these days do it |
rhodyguy |
Dec 7 2020, 03:45 PM
Near the headlight? How does that work? Multiple meters of high pressure silicon tubing? Like Rich Bontempi's old race car with the cool air ducting running thru the interior of the car?
Lo-Fi Version | Time is now: 6th May 2024 - 09:21 AM |
