Fasten Belts light |
Nacho |
Dec 5 2020, 03:54 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
914_teener |
Dec 5 2020, 09:31 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. |
Nacho |
Dec 5 2020, 09:49 PM
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ? Thanks Nacho |
914_teener |
Dec 6 2020, 08:46 PM
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ? Thanks Nacho Pretty sure you can search for wiring diagram. They are all switched grounds. Two are for the buzzer and seatbelt and IIRC the others are for the dome ligjt. Test the switch continuity first with a DVM before the goose chase starts. |
Nacho |
Dec 6 2020, 10:03 PM
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ? Thanks Nacho Pretty sure you can search for wiring diagram. They are all switched grounds. Two are for the buzzer and seatbelt and IIRC the others are for the dome ligjt. Test the switch continuity first with a DVM before the goose chase starts. Sweet thanks for the help. (IMG:style_emoticons/default/beerchug.gif) Nacho |
Lo-Fi Version | Time is now: 17th May 2024 - 08:49 PM |
