E-brake light & turn signal light |
JamesJ |
Dec 8 2020, 10:33 PM
Member Group: Members Posts: 222 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello All,
'74 with early gauges. Key in the off position, emergency brake on, turn signal in the neutral position(off), then turn the key to the first on position, the e-brake light flashes as does the turn signal indicator...both lights go out as they should when car is started. Is the e-brake light supposed to flash or light up solid? Not sure why the turn signal flashes with the e-brake light. Any help would be appreciated. Thanks! Attached File(s) IMG_5091.MOV ( 3.58mb ) Number of downloads: 23 |
terryth |
Dec 8 2020, 10:54 PM
Member Group: Members Posts: 57 Joined: 27-May 13 From: Nebraska Member No.: 15,929 Region Association: Upper MidWest |
The big light on top for the e brake it supposed to flash any time the emergency brake lever is pulled to warn you that the brake is on. I am pretty sure it flashes whether the car is running or not as long as the ignition is on and will only go out of the emergency brake lever is released down and it pushed the switch button in. I never paid attention of the small green turn signal lights in the center gauge do anything, their view is completely blocked by the grant steering wheel on my 74. I can telll the turn signals are on because the voltage gauge in the center console jumps with the signals
Hello All, '74 with early gauges. Key in the off position, emergency brake on, turn signal in the neutral position(off), then turn the key to the first on position, the e-brake light flashes as does the turn signal indicator...both lights go out as they should when car is started. Is the e-brake light supposed to flash or light up solid? Not sure why the turn signal flashes with the e-brake light. Any help would be appreciated. Thanks! |
JamesJ |
Dec 8 2020, 11:02 PM
That answers the e-brake light question, so we'll see if someone can answer the other part. Appreciate it, Terry.
barefoot |
Dec 9 2020, 07:44 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 17th May 2024 - 06:54 PM |
