Problem with Rennshift hitting floor |
hars914 |
Jul 16 2005, 05:56 PM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
I was installing my new Rennshift shifter today and ran into a problem.I adjusted
the shifter for the 30% throw and when I went to install it I noticed the clevis was hitting the floor pan and prevented the shifter from sitting flush on the tunnel. Has anyone had this problem?? Will I have to fab a spacer similar to the Weltmeister kit? I installed it with the 20% throw and it fit fine. It also was a real bitch getting the shifting right. I would get 1 thru 4 fine but it was not going into 5th.When I got it into 5th It would not go into 3rd. I finally got a happy medium and plan on test driving tommorow.Any thoughts on adjusting the pattern? |
Jul 16 2005, 06:09 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i just used 2 thick washer under each bolt. werks fine ... |
Kerrys914 |
Jul 16 2005, 06:11 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Strange. I have the 1st gen shifter and it works great. The finish is teh onlything I didn't like but it fits and shifts great (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I can shoot a photo of mine if you like. |
Rand |
Jul 16 2005, 07:00 PM
I have a stock shifter in good condition, guaranteed to work. I'll trade you straight across, and even pay shipping both ways! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Dang, I wish I had your problem. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Brad Roberts |
Jul 16 2005, 07:46 PM
Guy's.. it doesnt take much to dent the tub from the bottom. Take a small block of wood and push the pan back down. I would imagine this is the problem. The biggest issue I have seen with the shifter... some of them hit the clutch tube (if it was improperly repaired after breaking in the past) The bottom will swing out when you go for 4th gear and hit the clutch tube if the tube is not in its proper place.
B |
ChrisFoley |
Jul 16 2005, 07:54 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I think its possible to assemble incorrectly, with the pivot in the wrong hole IIRC. This causes it to sit too low in the housing.
Brad Roberts |
Jul 16 2005, 07:58 PM
I havent seen his "newest version" I know they are adjustable, but all they *should* be able to do is adjust where the fulcrum point is. Any pics?
B |
ChrisFoley |
Jul 16 2005, 08:08 PM
There are two mounting holes in the housing so the shift knob stays at the same height regardless of the ratio. |
Brad Roberts |
Jul 16 2005, 08:14 PM
I see said the blindman.
B |
Aaron Cox |
Jul 16 2005, 10:42 PM
mine was close to the floor...but didnt hit. great time to check your clutch tube also (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
BTW - they rock (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
hars914 |
Jul 18 2005, 05:29 AM
According to the instructions I had to remove the shift lever and move the
bushing from the bottom hole to the top hole. I set it back in the housing and screwed to the original mounting hole that I remove it from. You are right Chris there are also 2 holes in the housing.I mounted it back in the hole I removed it from. I will pull it today and reinstall the lever in the upper hole of the housing. |
RON S. |
Jul 18 2005, 07:12 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I got my new one over the weekend.
Mine is the 911 style for my 915 box. The shifter came with an approx 3/4" thick spacer glued under the back to mounting holes. I didn't know what it was for,as I thought all 3 hold down points would sit flush with the floor. I took it off,only to put it back on.The back end of my unit does sit pretty high off the floor.with it flush,the shift rod would bind.with is raised,it shifts fine. Just looks kinda dorky,it'll be covered by carpet though. I'll take some pics tonight to let ya'll see what I mean. Ron |
JWest |
Jul 18 2005, 08:00 AM
No, the shifter should sit flat to the floor. You need to move the support bracket under the floor, not sitting on top. |
RON S. |
Jul 18 2005, 11:18 AM
The problem that I have,has nothing to do with the shifter itself. Rather,it is the fact that during my resto,I needed to replace the entire shifter console because my original unit was so badly rusted out. The unit I replaced it with was with one from a later unit side shift car.There is a bulkhead down inside there that is causing my shift rod to ride high thru the console.I can see it when I look thru the exit hole in the firewall.I didn't know there'd be any interference issues,but ya find these things,with every turn of the wheel. I will be figuring a way to remove that bulkhead,then everything should be up to snuff.. Ron |
soloracer |
Jul 18 2005, 11:24 AM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
James,
Where are you in regards to delivery times on new shifters? I know a few months ago you weren't taking new orders until you took care of the back log. Just looking for an update is all. Thanks, Erik |
Lo-Fi Version | Time is now: 12th May 2024 - 07:40 AM |
