Oil leak, um... these things leak? |
MattR |
Jul 16 2005, 08:49 PM
I fired up my brand new 2056 and after my engine break in (12 minutes) I had a texas sized puddle under my car (im guessing a quart). It came from the oil cooler side, in that area. I dont know if pics would even help, but is there any way to check that my oil cooler seals seated properly? Originially I thought my galley plug wasnt fully seated (i drilled and tapped the galleys), but that appears to be snug. Or is there possibly something else in the area that would leak?
Jul 16 2005, 08:53 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
oil pressure sender ... oil filter ... |
MattR |
Jul 17 2005, 03:50 PM
Its not the sender, I just checked (bone dry).
The leak looks like it starts above the filter, right next to the cooler, or in that area. Is there any way for me to check the oil cooler seals and stuff? I took extra care in putting those things in, but maybe I still fuched it up (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
scotty b |
Jul 17 2005, 03:54 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Oh for the love of Pete. Britt has taken over your screenname. RUNNNNNN (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Tom Perso |
Jul 17 2005, 05:03 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Hell yes - I'd say oil cooler seals. What a PIA to put in, AND get them right. I usually use some Anarobic sealer (Hylomar) to stick the SOB's on, then be real careful with putting the cooler on.
You know what do to next. Tom |
bd1308 |
Jul 17 2005, 05:07 PM
if its not the sender, it's the oil cooler seals. my huge (2qt a day leak) was the sender.....
i have a smaller leak, but i'll wait a bit till i get the oil cooler seals....and at the same time, i'll order my pushrod tube seals. viton, of course (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
MattR |
Jul 17 2005, 05:33 PM
Have you done oil cooler seals with the engine in? Or does it require another engine drop...
914forme |
Jul 17 2005, 06:05 PM
MattR |
Jul 17 2005, 08:55 PM
I just took out the seals and covered them with Permatex 3H (they were dry before) and I STILL have a leak.
So far I see: the leak is coming from the oil cooler area its below the oil pressure sender it starts above the oil filter i just went through the oil cooler seals. is there anything else there that may be leaking??? Im really stuck |
bd1308 |
Jul 17 2005, 09:03 PM
and you re-did the galley plugs?
i dont recall anything else being there that leaks.... |
SGB |
Jul 17 2005, 09:04 PM
Ive gone through a series of valve cover gasket failures that released collassal amounts of oil. I also was certain it was the oil cooler seals and went through almost the entire replacement before I replaced the gasket, which had curled up away from the seating area- either an installation error or faulty gasket (uh, somehow...).
so anyway- check that right side gasket. |
bd1308 |
Jul 17 2005, 09:07 PM
right side is more prone to oil leaks anyway--less cooling efficiency.
Joe Bob |
Jul 18 2005, 04:41 PM
Did the cooler itself get pressure checked?
MattR |
Jul 18 2005, 04:43 PM
I got a brand new cooler from CB
MattR |
Jul 18 2005, 05:08 PM
Good suggestion. I was going to check that last night while I was in there, but I had to make a quick run to the ER (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) all is well though and i'll get back under there on thursday to check that out along with the source for the leak (i blasted the area after i gouped up the seals and ran it, so only new oil should be there). |
Lo-Fi Version | Time is now: 13th May 2024 - 07:16 AM |
