"Invisible" audio for the Porsche 914 |
horizontally-opposed |
Dec 20 2020, 12:43 AM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Plans to go for a drive in my 914 this weekend were dashed by yesterday's stay-at-home alert, so I finally dug into a minor project I've been putting off: Rebuilding the car's 28-year-old audio system. While it performed well for 15-20 years, a mixture of age, heat, moisture, etc eventually caught up to it.
System goals: 1) Install a system powerful enough to be enjoyed with the top on or off; 2) maintain/improve "period correct" appearance with no head unit and, if possible, no visible speakers; 3) minimize weight; 4) avoid or minimize additional holes/etc. I'm going into this with the understanding that it's entirely possible the exercise will be futile with a 2.2-liter flat six, but I have been collecting the parts over time and figure it's worth a shot. Some of this stuff has been sitting for years and thus may not be available anymore—but plenty of alternatives are. Old system components: Pyle graphic EQ turned on/off by factory rear defrost switch Pioneer fan-cooled amplifier (~1991) Boston Acoustics four-speaker set in doors (~1991) Pioneer ducted bass wedge in passenger footwell New system components: Smartphone with a proper mount > EQ Blaupunkt five-channel parametric EQ JL five-channel amplifier JL six-speaker set for factory speaker enclosures and door ?? subwoofer in passenger footwell (prepare for now, add later) Fair warning: This thread may proceed at a glacial pace, as midlife plus a small business means my days in the garage are fairly rare in this chapter. I'm also figuring this out as I go, and will use this thread as a journal and a place to share ideas. |
Rob-O |
Jan 13 2021, 12:47 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Those mids in the adapter plate look way too deep to fit in the stock location. I’d definitely test fit that. With the mid down low like that it’s not about crushing the paper heater hose. You can actually hit the small metal tube that is protruding from the rocker AND if it misses that can still be so deep that it hits the metal panel behind that.
Jan 13 2021, 12:53 PM
Those mids in the adapter plate look way too deep to fit in the stock location. I’d definitely test fit that. With the mid down low like that it’s not about crushing the paper heater hose. You can actually hit the small metal tube that is protruding from the rocker AND if it misses that can still be so deep that it hits the metal panel behind that. Thanks for reminding me to mention: I tested this setup for clearance to the original paper hoses in my car—out the very same concerns. The JL mids present no issues with clearance. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:06 PM |
