| stownsen914 |
Dec 20 2020, 09:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,037 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I'm looking for a cheap steering wheel hub for my 914 racecar, brand doesn't matter. The car is a '72, but for my purpose early or late style should work because I don't need to worry about the turn signal cancel on the backside for my application. I'll be shortening the hub and modifying it to accept a steering wheel quick release, so most any hub will do. Even a broken stock steering wheel would work as long at the hub portion is intact.
I have a Nardi hub that fits a late 914 to trade in case that's interesting to anyone. Thanks! |
| bdstone914 |
Dec 20 2020, 09:16 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm looking for a cheap steering wheel hub for my 914 racecar, brand doesn't matter. The car is a '72, but for my purpose early or late style should work because I don't need to worry about the turn signal cancel on the backside for my application. I'll be shortening the hub and modifying it to accept a steering wheel quick release, so most any hub will do. Even a broken stock steering wheel would work as long at the hub portion is intact. I have a Nardi hub that fits a late 914 to trade in case that's interesting to anyone. Thanks! I have a couple that should work for you. $20 plus shipping. Will dig them out and check the pattern. @stownsen914 |
| stownsen914 |
Dec 20 2020, 01:53 PM
| stownsen914 |
Dec 24 2020, 10:34 AM
Still looking - thanks
| mepstein |
Dec 24 2020, 12:01 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,007 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
This would be a correct hub for your 72. It was carefully removed from a stock wheel. The corrosion stains are from the steel spokes but will remove easily with a wire wheel or bead blasting. $20 + 8 ship.
| stownsen914 |
Dec 24 2020, 12:16 PM
mepstein - thanks, that'll work. Sending a PM.
Scott |
| stownsen914 |
Dec 25 2020, 08:15 AM
Thank you mepstein.
I'm actually looking for a second one of these if anyone has. Either a hub removed from a stock wheel, or a broken/damaged stock wheel. Merry Christmas! |
| Mark Henry |
Dec 25 2020, 03:29 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Can I ask are you making a custom shorter Momo hub adaptor?
For a quick release hub? If so is there a thread on this and/or could you please do a write up on your project. Thanks |
| stownsen914 |
Dec 25 2020, 04:41 PM
Can I ask are you making a custom shorter Momo hub adaptor? For a quick release hub? If so is there a thread on this and/or could you please do a write up on your project. Thanks Sure - I'm making a steering wheel quick release adapter (actually two of them, for a 911 and a 914). I am not happy with the off the shelf options because most of them put the wheel a few inches closer to the driver than I prefer. |
| 914ltd |
Dec 25 2020, 06:09 PM
Member ![]() ![]() Group: Members Posts: 247 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
I have a Porsche hub on Ebay, $24.95 with shipping. Brad
EBay listing 392927745319 |
| stownsen914 |
Dec 30 2020, 01:49 PM
Still looking for a second hub like the one I'm buying from mepstein (see above). Anyone got one? Or a broken stock steering wheel that I can salvage the hub from?
| GaroldShaffer |
Jan 2 2021, 06:49 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,664 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
I have one off an early 70 wheel if that works for you.
Same deal as Mark. $20 plus $8 shipping. Attached image(s)
| stownsen914 |
Jan 2 2021, 01:42 PM
Garold - thanks, that should work. Sending a PM.
| stownsen914 |
Nov 21 2026, 01:30 PM
I'm looking for one more of these now. Ideally the bare hub removed from a stock early 914 steering wheel. Anyone got one?
Lo-Fi Version | Time is now: 21st November 2026 - 11:59 PM |
