Sebring Seats-GTS Classics |
JamesJ |
Dec 23 2020, 07:59 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello All,
Has anyone driven or sat in a 914 with a Sebring seat from GTS Classics? I have read several previous threads regarding these aftermarket seats. The owner, Stefan, told me that the Sebring is two notches above the stock 914 seat as far as support goes, with the LeMans being the first step up. From the looks of the two seats, the LeMans appears to offer mostly hip support, whereas the Sebring looks to offer both hip and torso support. I am not racing the car and I do want to keep the backpad. The Sebrings have a much sharper angle at the back of the seat than do the stock seats, so I am not expecting them to sit snug in the backpad recess, but I don't want them to look too out of place either. I imagine with the back of the seat at such an angle, my reach to the steering wheel will be a bit longer. I will be using my stock '74 shoulder belt, but Stefan recommended using a rear seat belt receptacle from a 911 to use in place of the stock 914 receptacle so that I can loop it through the hole that would be made in the seat, as in the photo below. Any experience or thoughts on the driving feel of these seats or the way they look at the back/against the backpad would be appreciated. Thanks! |
VegasRacer |
Dec 23 2020, 10:11 PM
ELVIRA Group: Benefactors Posts: 8,501 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I have no experience with the Sebring seat, but I am beyond satisfied with my LeMans seat from Stephan at GTS.
It is very comfortable on long drives and supportive at the track with my five point harness. |
cali914 |
Dec 23 2020, 11:06 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
I had a corbeau seat similar but being 6'0 the back had to be mounted all the way against the wall.
Sway Bar |
Dec 23 2020, 11:07 PM
Member Group: Members Posts: 88 Joined: 17-December 19 From: Okanagan Valley, Great White North Member No.: 23,743 Region Association: None |
So no experience with this particular seat but I have used 3 of Stefan's seats. All are great for comfort and of course you can go with all kinds of custom finishes. You can even give him your height etc. and he may recommend accordingly.
In the 914 we discussed and I ended up using the Hockenheim seat of his. Very similar to the Scheel seats. I think the upper support is a little less and makes it easier for ingress and egress. I'm pretty sure the sub frame for his seats will be very similar to the Sebring so maybe you can get an feel for the rake of the back rest from my pictures. I of course am not using the back pad so you may have to envision if that looks different. I'm 6'2" and I still have the seat slightly forward but again no back pad. One thing you must take into consideration is that he has his own seat mount spacing (unless the Sebring is different) and they do not bolt onto the 914 seat rails. I spend some time making them adapt the 10-15mm they were out but then found the seat sat way too high for my liking so I adapted some early very flat 911 seat brackets and the basically sit right on the cross member (kinda equivalent to the lowest seat seating) and they allow me to slide forward and back. He does have his own adapters and rails. I also use a smaller Momo wheel. I think the regular wheel with high torso support will make it much more difficult to enter/exit as a street car. As for seat belts, if you want to stay Porsche I gather any early REPA receiver should work. I think the very early 914's had 'floppy' receivers and manual belts?? Hope this gives a little guidance. At least you can ask him the difference in these 2 seats and you have a visual reference. |
tygaboy |
Dec 23 2020, 11:14 PM
914 Guru Group: Members Posts: 5,285 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
James - I have the LeMans seats with the seat belt pass throughs. You're welcome to bring your car by some time and we can swap in the driver's seat for you to check out. At least you'd have some first hand knowledge of if you like them or want something different.
Note that the belts pictured are from Seat Belt Planet and use belt material instead of wire on the buckle side. These also use a different buckle - I did this because this buckle fits through the pass through, making seat removal that one bit simpler. And if you'd like to talk details, PM me and we can coordinate a call. Attached image(s) |
BillJ |
Dec 23 2020, 11:29 PM
Senior Member Group: Members Posts: 1,094 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Very interested in this thread as i just got a quote from Stefan on a pair of LeMans seats for the 75. I had scheels in my 73 before turning it to tack only use and liked how those felt but feel like too much upper torso support makes it harder to live with for street only.
VegasRacer |
Dec 24 2020, 12:30 AM
Very interested in this thread as i just got a quote from Stefan on a pair of LeMans seats for the 75. I had scheels in my 73 before turning it to tack only use and liked how those felt but feel like to much upper torso support makes it harder to live with for street only. You won't regret it. (IMG:style_emoticons/default/biggrin.gif) I replaced my Scheel with a LeMans 15 years / 100K miles ago. (IMG:style_emoticons/default/driving.gif) I am still as happy with my purchase as I was on day one. |
BillJ |
Dec 24 2020, 08:02 AM
Back to the top. Anyone have pics of the OP request of Sebring seat in the car?
JamesJ |
Dec 24 2020, 02:17 PM
Thanks for all of the responses!
@VegasRacer...good to know that the LeMans has worked well for you both on the street and track for so many years. I will consider that. @cali914...I am 6' as well, and you had to remove the backpad to get the corbeau to fit? @Sway Bar...those are beautiful seats. I have a Momo Prototipo with a hub eccentric. I can see where the eccentric helps to get in and out if the front of the seat is at a higher position, as it appears the Hockenheim are that way. @tygaboy...thanks Chris. I'll take you up on your offer and text you next week to set something up. Super kind of you to offer. |
gereed75 |
Dec 24 2020, 03:12 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
These are my all time favs. GTS Watkins Glen I believe. They belong to a member
Suggest you search Stephan’s posts as a good place to get knowledge. His user name is GTS |
double-a |
Dec 24 2020, 04:01 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
jim_hoyland |
Dec 24 2020, 06:58 PM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Bought these leather GTS Le Mans seated with heathers installed over 10 years ago. Really liked working with Stephan and appreciate the craftsmanship in the seats.
The Le Mans fit nicely into the backpack recess, some GTS seats do not. Attached image(s) |
raynekat |
Dec 25 2020, 09:15 PM
Advanced Member Group: Members Posts: 2,157 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
The GTS Watkins Glen model seats are definitely made for the 914.
They still fit into the recess of the back pad. I got the bare fiberglass...I think they normally would paint the back sides of the seats black. Here they are in my car. I am taller at 6'2" and big enough at 205 lbs and fit into the seats with no problems. They have great lateral support for whatever you might want to do with your car....street, auto-x, track, etc. The quality was 1st rate as well. |
gereed75 |
Dec 26 2020, 08:19 AM
Yep, this just reinforces that these are my all time favs!!! The Tartan is 100% class and Your car is very cool.
The way Stephan alined the white stripes in the Tartan show his artistry Thanks for posting Rayne |
Rleog |
Dec 26 2020, 10:16 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
The Watkins Glen was my choice. Fits excellently. Doesn’t interfere with the parking brake. Love the side support in spirited cornering.
(Looks large in the picture due to being in the foreground of the photo..... just camera perspective.) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1239-1608999378.1.jpg) |
pete000 |
Dec 26 2020, 10:53 AM
Love the raw fiberglass variant ! Good thing for my old six is I would only need one !
chrisg |
Dec 26 2020, 08:28 PM
Member Group: Members Posts: 63 Joined: 20-December 03 From: Paso Robles, CA Member No.: 1,455 Region Association: None |
OK, so maybe I just can’t see it without all of them being pictured side by side, but which version has the easiest ingress/egress? They all seem to add enough side support but I am just not seeing clear advantages or disadvantages of one over the other. Can some expand on why they picked one over the other?
tygaboy |
Dec 26 2020, 11:00 PM
OK, so maybe I just can’t see it without all of them being pictured side by side, but which version has the easiest ingress/egress? They all seem to add enough side support but I am just not seeing clear advantages or disadvantages of one over the other. Can some expand on why they picked one over the other? @chrisg - IMO: Stock = none/not much hip or upper torso support LeMans = greatly improved hip support, and a bit more upper torso support Watkins Glen = hip support plus even better upper torso support In the end, it's down to some combo of personal preference (do you fit comfortably in seat X?), desired look and use case. I like my LeMans but am considering selling them and getting something with more upper support. |
horizontally-opposed |
Dec 26 2020, 11:35 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Been down this road, with three pairs of seats.
Seating is extremely personal, but the stock seats seem to be extremely comfortable on long drives for most people. Always got a lot of comments about that, and from a wide variety of people/body types; the lack of negative comments were even more impressive…until the corners came up. Just as a number of passengers did, I wanted more support. I wish there had been a thread like this one back then. A lot of good inputs, and experiences shared. I'll add two more: 1) GTS Classics "Le Mans" seats in vinyl/basketweave were my first move, and Stefan was great to deal with. Added heating elements, and also asked for basketweave on the sides of the lower cushion—an idea I had after seeing a similar treatment in a 908. Added a bit of dimensionality. What's great is GTS will do things like this. I was impressed with the workmanship of the seats for the price, their strap system for the lower cushion, and the way they fit into the stock 914 back pad. Unfortunately, they didn't offer the upper torso support I was after—though they did lock my rear end into the seat. I spent some extra money to "shrink" the 914-style headrests, which looked too big to me, but the bigger issue may have been personal: The way I sat in them left me uncomfortable after even medium distances. They weren't a match for me; I wondered if I should have done something more like an ST seat, though those Watkins Glen with Tartan have me wondering… (IMG:style_emoticons/default/wub.gif) 2) I decided to try Scheels after Russ @bullethead offered a very nice pair of Scheels when I was in Florida. Having sat in Scheels before, I knew they would offer the torso support I was after, and hoped they would be more comfortable for me on longer trips. Turns out, they're both—and they mount perfectly on the stock seat rails. They are a bit restrictive (I can't imagine they're fun for someone wider than me), and ingress/egress will be tricky for some, but I really like them. I'll use them for a while, and then have them restored in similar materials. If at all possible, try to sit in the seats before you buy. Replicate the angle they'll be mounted at if you can, and bring a book/tablet/phone/etc and read for at least 30 minutes if you can. What I discovered: Seats might be the most important interface in a car. If they're good, you can drive all day. If they're bad (for you), you won't drive the car nearly as much. |
VegasRacer |
Dec 27 2020, 12:11 AM
What I discovered: Seats might be the most important interface in a car. If they're good, you can drive all day. 100 % TRUE. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_flagge24.gif) My seat search journey was the exact opposite of @horizontally-opposed . The Scheels worked fine for me at the track, but I was crying uncle two hours into a road trip. I was one of Stefan's early customers. The Watkins Glen was not available. I sat in a LeMans he had on display at a racetrack and refused to get up until we made a deal. It has proved to be one of the best investments I have ever made. Seats are Personal. (IMG:style_emoticons/default/bootyshake.gif) Try before you buy. (IMG:style_emoticons/default/biggrin.gif) It's worth it. (IMG:style_emoticons/default/hijacked.gif) Don't get me started on how much I (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/hearts.gif) (IMG:style_emoticons/default/wub.gif) the Carbon Fiber Sport Buckets in my Cayman R. |
Lo-Fi Version | Time is now: 5th May 2024 - 08:20 PM |
