> Vented Rotor Stock Strut, Yes it all bolts on
djway
post Dec 29 2020, 09:32 PM
Post #21
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts
07,08 cayman, 05-08 boxster 2.7L (non-S) rotors.
298x24 front
299x20 rear.
Calipers 97-08 Boxster
07-08 Cayman
Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled.
Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter.
I have not tried but am told 15” alloy works.
Rear
Front
Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair.
edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out.
djway   Vented Rotor Stock Strut   Dec 29 2020, 09:32 PM
Robarabian   Who makes the adapter?   Dec 29 2020, 09:51 PM
djway   Who makes the adapter? I Worked with VDUBENGINEE...   Dec 29 2020, 10:12 PM
djway   For you early strut guys the Sebro vented rotor fo...   Dec 29 2020, 11:01 PM
Lanner   Hi guys, My name is Lanner. I built this setup. I...   Dec 30 2020, 12:18 PM
DRPHIL914   Hi guys, My name is Lanner. I built this setup. ...   Dec 30 2020, 12:56 PM
mepstein   [quote name='Lanner' post='2879113' date='Dec 30 ...   Dec 30 2020, 01:19 PM
Lanner   Dr Phil, Correct on front setup. You need the hub...   Dec 30 2020, 01:23 PM
djway   Dr Phil, Correct on front setup. You need the hu...   Dec 30 2020, 04:56 PM
Montreal914   Thank you for posting. This will get a lot of att...   Dec 30 2020, 12:25 PM
preach   Very cool!   Dec 30 2020, 12:30 PM
Lanner   Djway has been a great help, measuring things for ...   Dec 30 2020, 01:04 PM
DRPHIL914   Djway has been a great help, measuring things for...   Dec 30 2020, 01:19 PM
Lanner   Here's a VW I built on the same brake setup, 1...   Dec 30 2020, 01:29 PM
DRPHIL914   [quote name='Lanner' post='2879113' date='Dec 30...   Dec 30 2020, 01:33 PM
mepstein   [quote name='mepstein' post='2879144' date='Dec 3...   Dec 30 2020, 02:33 PM
Lanner   I agree mepstein, you are adding unsprung weight. ...   Dec 30 2020, 01:37 PM
Montreal914   Super cool bug! :) I would be curious to kn...   Dec 30 2020, 01:58 PM
Mark Henry   Super cool bug! :) I would be curious to k...   Dec 31 2020, 08:29 AM
pete000   Parking brake option...lol   Dec 30 2020, 02:28 PM
MM1   Parking brake option...lol Yep-2 of those tank...   Dec 30 2020, 02:53 PM
Lanner   @montreal914 , funny you should ask...are you in M...   Dec 30 2020, 02:32 PM
Montreal914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 30 2020, 02:42 PM
Lanner   The Boxster are 130mm radial mount. Most 911 is 89...   Dec 30 2020, 04:15 PM
djway   I found Lanner through an insane VW Fastback build...   Dec 30 2020, 04:51 PM
Lanner   @djway , the pictured calipers are just repainted ...   Jan 5 2021, 02:43 PM
ThePaintedMan   @djway [b]@[url=http://www.914world.com/bbs2/ind...   Jan 7 2021, 06:39 PM
djway   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 7 2021, 09:28 PM
Lanner   @ThePaintedMan . The hubs are dual pattern, so you...   Feb 17 2021, 11:01 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:46 PM
