914 LS conversion from renegade hybrids |
speed metal army |
Jan 3 2021, 06:10 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
I have all the RH goodies for an LS swap. Uses 901 transaxle. Engine bar, electric WP, adapter plate, clutch/flywheel and full radiator setup and all hoses, overflow can etc etc.. Also all the engine conversion bits, alt bracket, cooling plates etc. Probably 2000 miles tops on all the stuff, I just dont drive as much as I would like to. I also have the super slim oil pan that gives max clearance when running this set up, and the trans mounts too. Worked flawlessly, the RH stuff is proven. I also have the muffler setup I made to run with the short truck LS manifolds.
RH-$4500 Speed Metal-$2600 |
Lo-Fi Version | Time is now: 18th May 2024 - 01:32 PM |
