Nuts and Bolts, Sourcing the right hardware. |
Chaznaster |
Jan 3 2021, 06:54 PM
Member Group: Members Posts: 290 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9).
Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones? Thank You! |
mepstein |
Jan 3 2021, 07:11 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Short answer is no list is available.
First, save all the old hardware, it can be refinished. Use Porsche PET, I like this one -https://nemigaparts.com/cat_spares/pet/porsche/914/570u/ to get the correct sizes. IIRC, some of the bolts that hold the front suspension to the car are grade 10 and the rest is grade 8 but I could be making that up. Belmetric is a great source to order a couple or a whole bunch. When I worked at the Porsche shop, we just ordered a box of every size nut and bolt from Wurth but that only makes sense if you are doing a bunch of cars. Better to just order what you need from Belmetric. They are very reasonable priced for hardware but you want to try to group your orders or shipping adds up quickly. |
914 RZ-1 |
Jan 3 2021, 07:19 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
There happens to be a supplier of metric hardware in my town (Metric Specialties) and I would take the old nut/bolt/etc. to them and see if they had it. I also found that a small, local hardware store (in my case a True Value) would often have what I needed. Lastly, the Lowes near me seems to have a better selection of metric stuff than the Home Depot.
TonyA |
Jan 3 2021, 07:54 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Auto Atlanta has or had a kit with a list of some sort on fasteners.
mepstein |
Jan 3 2021, 08:29 PM
wes |
Jan 3 2021, 09:36 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Auto Atlanta has or had a kit with a list of some sort on fasteners. I have the kit. It’s mostly interior fasteners. I used the kit as well and agree although definitely helpful in my case as I stripped my car too bare metal inside and out not the undercarriage. |
Dave_Darling |
Jan 3 2021, 11:30 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I bought a kit many years ago with lots of DIN-spec nuts, bolts, and washers. (Note that generic "metric" may be JIS, which uses different wrench sizes for many of the fasteners than DIN does!!) Came in a blue metal case with compartments for the different fasteners. I would stop over to the local metric supply place (who hasn't done in-store sales in a very long time now) to get lots of extras of items I ran low on.
The most common fasteners in our cars are M6 and M8. Those are the 10mm and 13mm wrench ones. (JIS uses 12mm for M8 fasteners!) Almost everything seems to have a wavy washer on it as well. And there are a bunch of different lengths of each used. I wound up getting boxes of 100 each of a bunch of them. Still have a good bit of them but can't find them now. Three moves will do that to a fella. --DD |
914e |
Jan 4 2021, 01:12 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9). Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones? Thank You! I just happened to place an order with Belmetric, This isn't every nut bolt and screw. It is about every m5, 6, 8,10, and 12 except the engines hardware. I also have 3 German cars so there is few spares. I'm buying steel cabinets with plastic divided boxes from Bolt depot. My attempt to have an ACE hardware in my garage, plus the hardware will be the right color. I hope to cut back on my weekly runs to ACE and returning with a tiny bag of hardware that I spent $20 on. 10 x BR6X8YLW - Hex Bolt 8.8 Yellow Zinc $1.60 25 x BR6X10YLW - Hex Bolt 8.8 Yellow Zinc $4.25 25 x BR6X12YLW - Hex Bolt 8.8 Yellow Zinc $4.50 10 x BR6X14YLW - Hex Bolt 8.8 Yellow Zinc $2.30 25 x BR6X20YLW - Hex Bolt 8.8 Yellow Zinc $5.25 4 x BR6X18YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR6X16YLW - Hex Bolt 8.8 Yellow Zinc $0.72 10 x BR6X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $2.30 25 x BR8X10YLW - Hex Bolt 8.8 Yellow Zinc $5.50 5 x BR8X14YLW - Hex Bolt 8.8 Yellow Zinc $1.45 20 x BR8X16YLW - Hex Bolt 8.8 Yellow Zinc $5.60 10 x BR8X20YLW - Hex Bolt 8.8 Yellow Zinc $2.90 10 x BR8X25YLW - Hex Bolt 8.8 Yellow Zinc $3.70 11 x BR8X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.29 10 x BR8X40PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.10 10 x BR8X45PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.50 4 x BR10X85YLW - Hex Bolt 8.8 Yellow Zinc $4.68 10 x BR10X18YLW - Hex Bolt 8.8 Yellow Zinc $4.70 10 x BR10X20YLW - Hex Bolt 8.8 Yellow Zinc $4.20 4 x BR10X22YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X16YLW - Hex Bolt 8.8 Yellow Zinc $1.60 4 x BR10X25YLW - Hex Bolt 8.8 Yellow Zinc $1.88 4 x BR10X30YLW - Hex Bolt 8.8 Yellow Zinc $1.96 4 x BR10X35YLW - Hex Bolt 8.8 Yellow Zinc $2.24 10 x BR5X10YLW - Hex Bolt 8.8 Yellow Zinc $2.40 10 x BR5X20YLW - Hex Bolt 8.8 Yellow Zinc $2.40 4 x BR5X12YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR5X22YLW - Hex Bolt 8.8 Yellow Zinc $0.96 4 x BR12X80PYLW - Hex Bolt 8.8 Yellow Zinc Partial $6.12 10 x BR12X30YLW - Hex Bolt 8.8 Yellow Zinc $7.10 4 x BR12X60PYLW - Hex Bolt 8.8 Yellow Zinc $3.56 50 x WF6YLW - Flat Washer Yellow Zinc $4.50 50 x WF8YLW - Flat Washer Yellow Zinc $6.00 20 x WF6X11YLW - Flat Washer Small OD Yellow Zinc $1.80 10 x WF8X15YLW - Flat Washer Small OD Yellow Zinc $1.20 25 x WFHV6YLW - Hardened Flat Washer Yellow Zinc $3.25 10 x WW6AMECYLW - Wave Washer Mechanical Yellow Zinc $1.20 10 x WW7BYLW - Wave Washer Yellow Zinc $2.10 10 x WSH6YLW - Schnorr Washer Yellow Zinc $1.90 10 x WSH7MECYLW- Schnorr Washer Mechanical Yellow Zinc $2.60 25 x WL5MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL6MECYLW - Lock Washer Mechanical Yellow Zinc $2.00 25 x WL8MECYLW - Lock Washer Mechanical Yellow Zinc $3.50 25 x WL10MECYLW - Lock Washer Mechanical Yellow Zinc $3.75 10 x WL12MECYLW - Lock Washer Mechanical Yellow Zinc $1.90 20 x NR6YLW - Hex Nut Yellow Zinc Class 8 $2.00 20 x NR8YLW - Hex Nut Yellow Zinc Class 8 $3.20 10 x NR10YLW - Hex Nut Yellow Zinc Class 8 $2.30 4 x NR12YLW - Hex Nut Yellow Zinc Class 8 $1.00 4 x NNFH6YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.16 4 x NNFH8YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.44 4 x NNFH10YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.96 20 x E302NT - 6.3mm Uninsulated Spade 16-14 Gauge No Tab $7.00 20 x E922TABBRS - 6.3mm Uninsulated Spade 18-16 Gauge With Tab $6.80 4 x E308BRS - 6.3mm Uninsulated Male Spade With Tab 16-14 Gauge $2.04 10 x E922NTTIN - 6.3mm Uninsulated Spade 20-17 Gauge No Tab $4.00 $171.16Sub-Total: $0.00Free Shipping Options (EXPECT DELAYS - Free Shipping): $171.16 |
campbellcj |
Jan 4 2021, 08:23 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
^^^ Thanks for that list, that's awesome. I typically try to re-use original fasteners unless too mangled or ugly. I've bought several of those kits from AASE Sales and Pegasus and then supplement/restock as needed but it can really add to timeframes and frustrations when you fall short on bits. The washers in particular get thrashed or lost easily and are not corner hardware store stuff.
Chaznaster |
Jan 4 2021, 07:51 PM
Wow! That long list is amazing! And the final price is great, considering how much was ordered.
Thanks to everyone for the recommendations. It looks like I am headed to Belmetric for a shopping spree. I will always try to use the original except when it is obvious it has been changed. Will keep and refinish wherever I can. Thanks all!! |
Jett |
Jan 4 2021, 09:04 PM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Wow! That long list is amazing! And the final price is great, considering how much was ordered. Thanks to everyone for the recommendations. It looks like I am headed to Belmetric for a shopping spree. I will always try to use the original except when it is obvious it has been changed. Will keep and refinish wherever I can. Thanks all!! Sounds like a good plan. I went the re-plate and replace with original (new and used) route and would not be surprised if it cost 10x and took months to execute. I am ordering that list for our next build (IMG:style_emoticons/default/smile.gif). Thanks! |
914e |
Jan 6 2021, 01:32 PM
Belmetric is amazing. Fed-ex just dropped a small heavy package. Free two day shipping. My daughters are asking me, dad did you just buy the metric hardware section of Ace?
aharder |
Jan 6 2021, 02:01 PM
Advanced Member Group: Members Posts: 4,375 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I buy most all of my fasteners from Belmetric, they have a great selection and great inventory levels, don't think I have ever had a back order from them.
mepstein |
Jan 6 2021, 02:35 PM
I buy most all of my fasteners from Belmetric, they have a great selection and great inventory levels, don't think I have ever had a back order from them. Same here. (IMG:style_emoticons/default/beerchug.gif) |
RiqueMar |
Jan 6 2021, 04:39 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Just adding my 2-cents to the thread....
I purchased the Auto-Atlanta kit and talk a bit about it on my build thread (Link here). If I remember correctly, 914Rubber.com was looking at producing an entire kit. ..... Maybe if enough of us bug them, we can get something! (IMG:style_emoticons/default/shades.gif) |
bkrantz |
Jan 6 2021, 07:54 PM
914 Guru Group: Members Posts: 7,739 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I buy most all of my fasteners from Belmetric, they have a great selection and great inventory levels, don't think I have ever had a back order from them. Same here. (IMG:style_emoticons/default/beerchug.gif) Me, three. Got another box from them today. |
RestoReese |
Jan 6 2021, 08:55 PM
Newbie Group: Members Posts: 31 Joined: 29-June 19 From: Dallas, TX Member No.: 23,256 Region Association: Southwest Region |
I just learned there is a place called Belmetric. This may have saved me years of my life zipping around town trying to find things, and I think I can afford my kids college tuition now.
Thank you 914world! |
barefoot |
Jan 6 2021, 10:02 PM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9). Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones? Thank You! Death to the cheeseheads !! I replaced every one on my engine including all the warm air guides with SS socket head screws. Bought a box from McMaster Carr & never looked back (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Jan 6 2021, 11:14 PM
The rubber man Group: Members Posts: 12,641 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are actually putting together area specific kits now. Finish is chromate just like factory. Yellow zinc looks pretty for awhile but zinc is a sacrificial anode. It will not stay pretty.
If you notice many original fasteners still look good when you take them off. More to follow. |
iankarr |
Jan 9 2021, 11:32 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Thanks @914e for this great shopping list. Super helpful. I'd add M8 schnorr washers for the CV bolts (16...but since you need to replace at least 8 of them every time you drop the engine, I'd get 50).
Lo-Fi Version | Time is now: 29th April 2024 - 07:17 PM |
