Headlights work on dim but not bright, headlights wont stay when bright switch is engaged |
Brenda |
Jan 5 2021, 04:10 PM
Newbie Group: Members Posts: 4 Joined: 31-December 17 From: Texas Member No.: 21,743 Region Association: None |
Porsche 914 1973 headlight problem.
The lights pop up - dim lights come on but when I try to use the bright headlights the brights stay on while the handle is held but then when I release the handle the lights go out completely. When I pull the handle again the dims come back on. I have replaced the switch but same problem Any ideas? Thanks brenda |
bdstone914 |
Jan 5 2021, 04:19 PM
Porsche 914 1973 headlight problem. The lights pop up - dim lights come on but when I try to use the bright headlights the brights stay on while the handle is held but then when I release the handle the lights go out completely. When I pull the handle again the dims come back on. I have replaced the switch but same problem Any ideas? Thanks @brenda Possibly the Hi/low headlight relay. It is on the top of the fuse panel under the dash. Check fuses 1 through four. They control hi and low beams |
terryth |
Jan 5 2021, 04:32 PM
Member Group: Members Posts: 57 Joined: 27-May 13 From: Nebraska Member No.: 15,929 Region Association: Upper MidWest |
Likely the relay, it attaches to the back of the fuse panel. I just replaced mine.
Porsche 914 1973 headlight problem. The lights pop up - dim lights come on but when I try to use the bright headlights the brights stay on while the handle is held but then when I release the handle the lights go out completely. When I pull the handle again the dims come back on. I have replaced the switch but same problem Any ideas? Thanks brenda |
Lo-Fi Version | Time is now: 19th May 2024 - 02:44 PM |
