trick-e |
Still Learning ![]() ![]() Group: Members Posts: 119 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest ![]() ![]() |
Car is stored and battery is out. Looking for a decent maintenance charger for an AGM battery. There are quite a few choices, so anyone with a good experience?
pvollma |
Member ![]() ![]() Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region ![]() ![]() |
Car is stored and battery is out. Looking for a decent maintenance charger for an AGM battery. There are quite a few choices, so anyone with a good experience? I used a PulseTech Xtreme Charge on my airplane, which in the winter got very little use, but the few times I pulled it out, after sitting for maybe a month or two, the battery had no trouble spinning the prop. I sold the airplane last year and I've now moved the PulseTech to my 914 because the last time I tried to drive it the Odyssey PC1200 barely turned it over. I also like the fact that it comes with a short connector that can be installed on the battery posts, with a quick disconnect to the longer cable to the charger, instead of using the spring clips that seem too temporary to trust for long-term use. As the name implies, it also uses a pulsing routine to de-sulfate the battery. PulseTech |
Lo-Fi Version | Time is now: 2nd July 2025 - 10:13 PM |
