914-6 conversion package oil tank and sheet metal |
mb911 |
Jan 13 2021, 07:22 PM
914 Guru Group: Members Posts: 6,831 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am offering 2 kits to get your conversion folks started off right.
Includes one of my aluminum oil tanks and a set of restoration designs stamped engine sheet metal. The sheet metal retails at $1000 and my tanks are $700 retail . Offering these as a spring deal. $1200 shipped for the pair. Attached are just stock pictures. The sheet metal is with holes for heat. |
mb911 |
Jan 15 2021, 06:01 AM
Bump
914Sixer |
Jan 15 2021, 01:52 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I sure wish I was doing a conversion. Smoking deal (IMG:style_emoticons/default/pray.gif)
burton73 |
Jan 15 2021, 04:13 PM
burton73 Group: Members Posts: 3,514 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
If I was doing a conversion I would be all over this. Today great deal!
Great work Ben. Bob B |
mb911 |
Jan 18 2021, 04:18 PM
Still available and ready for immediate shipment
930cabman |
Jan 26 2021, 07:25 AM
Advanced Member Group: Members Posts: 3,017 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required?
thank you, |
mb911 |
Jan 26 2021, 08:33 AM
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required? thank you, It fits perfectly in the factory opening. You will have to modify for the carrera tensioners if you have those otherwise your all set. Paint and bolt on. As to the tank you have to drill holes and properly layout from the tank, then bolt in |
930cabman |
Jan 27 2021, 05:33 PM
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required? thank you, It fits perfectly in the factory opening. You will have to modify for the carrera tensioners if you have those otherwise your all set. Paint and bolt on. As to the tank you have to drill holes and properly layout from the tank, then bolt in Don't tell anybody, but sign me up, check your PM Thanks |
yostcorners |
Jan 29 2021, 10:19 AM
Newbie Group: Members Posts: 1 Joined: 14-March 19 From: peachtree corners, ga Member No.: 22,957 Region Association: South East States |
I am offering 2 kits to get your conversion folks started off right. Includes one of my aluminum oil tanks and a set of restoration designs stamped engine sheet metal. The sheet metal retails at $1000 and my tanks are $700 retail . Offering these as a spring deal. $1200 shipped for the pair. Attached are just stock pictures. The sheet metal is with holes for heat. I will take these parts if still available. Thanks, Jon Yost. 404 838 7444. |
mb911 |
Jan 29 2021, 12:53 PM
Jon, I can have one more setup ready for you on Monday. Pm your details and I will send an invoice. |
930cabman |
Jan 29 2021, 04:11 PM
I am offering 2 kits to get your conversion folks started off right. Includes one of my aluminum oil tanks and a set of restoration designs stamped engine sheet metal. The sheet metal retails at $1000 and my tanks are $700 retail . Offering these as a spring deal. $1200 shipped for the pair. Attached are just stock pictures. The sheet metal is with holes for heat. I will take these parts if still available. Thanks, Jon Yost. 404 838 7444. Welcome aboard, I have been connected with the 914 World for a short time and everyone has been very helpful. I also am starting down the /6 conversion road. |
Lo-Fi Version | Time is now: 8th May 2024 - 08:06 AM |
