914-6 conversion package oil tank and sheet metal |
mb911 |
Jan 13 2021, 07:22 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am offering 2 kits to get your conversion folks started off right.
Includes one of my aluminum oil tanks and a set of restoration designs stamped engine sheet metal. The sheet metal retails at $1000 and my tanks are $700 retail . Offering these as a spring deal. $1200 shipped for the pair. Attached are just stock pictures. The sheet metal is with holes for heat. |
930cabman |
Jan 26 2021, 07:25 AM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required?
thank you, |
mb911 |
Jan 26 2021, 08:33 AM
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required? thank you, It fits perfectly in the factory opening. You will have to modify for the carrera tensioners if you have those otherwise your all set. Paint and bolt on. As to the tank you have to drill holes and properly layout from the tank, then bolt in |
930cabman |
Jan 27 2021, 05:33 PM
Looks like a great deal, I am building an inventory for a future -6 build. It will be a 2.7. With the tin furnished with your kit, is it a proper fit into the engine bay, or what else is required? thank you, It fits perfectly in the factory opening. You will have to modify for the carrera tensioners if you have those otherwise your all set. Paint and bolt on. As to the tank you have to drill holes and properly layout from the tank, then bolt in Don't tell anybody, but sign me up, check your PM Thanks |
Lo-Fi Version | Time is now: 5th May 2024 - 05:46 AM |
