Help identifying this transmission |
mate914 |
Jan 15 2021, 07:43 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
rgalla9146 |
Jan 15 2021, 08:26 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
A trans with a 911 prefix is for a '70-'71 911.
Next came the 915 The '911' trans was the first to incorporate a 'pull' type pressure plate. It has cast in features that the clutch tube and cable are guided by/attached to. The one on the right (upside down) appears to be a 911 type.....that flange secures the end of the clutch cable. What rear cover is on that trans ? If it has a 914 rear cover it was probably mated to a later engine to use the pull type clutch. Don't forget this involves flipping the ring and pinion and FULL re-set of all tolerances. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:41 AM |
