Rebuilding a 1.7, Want to rebuild my 1.7, need as much help as I can get |
barnfind9141972 |
Jan 17 2021, 12:20 AM
Member Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
Hi everyone, given how awesome this site is and the wealth of knowledge I’d like to do what seems like the best option for me and that is get my 914 on the road and keep it on the road. Need some help, advice, how to’s, anything that could help me build the motor. I’m mechanically inclined, I’ve built an engine before on a 2.5 Nissan Sentra (i know dark times before) but only did the easy stuff like assemble after a machinist put the crank and rods in. I’ve been restoring in the garage for about a month or so and although the engine “ran” when parked 20 years ago it seems like the right time to rebuild. What parts should I use, any good videos to watch, anything to read, how can an average guy like me split the case open and handle the rebuild step by step while killing time in the garage? Open to suggestions on displacement, fuel delivery, places for machine work, any suggestions and even sarcasm are accepted. Big fan of Ian Karr so have been watching his videos, just waiting for the final release of his engine build for more insight Thanks everyone! (IMG:style_emoticons/default/sawzall-smiley.gif)
Shivers |
Jan 18 2021, 11:12 AM
Senior Member Group: Members Posts: 2,396 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I did this build many years ago. I was working in el toro, so I dropped off a crank at Scat enterprises. They made the counter balanced crank. Rods were stock and were balanced along with the pistons. I went with Kolbenschmidt euro flat top pistons and barrels. Machine work was done in Torrance, I don't remember the name of the place. Flycut the heads and case for barrels, line bored the case one over to true up the case for the new crank.
ARB fasteners, case savers and had the oil plugs on the back of the case (between case and flywheel) removed and welded up. When you decide what type of fuel delivery you'll use, you can speak to someone about a cam. |
barnfind9141972 |
Jan 18 2021, 08:13 PM
I did this build many years ago. I was working in el toro, so I dropped off a crank at Scat enterprises. They made the counter balanced crank. Rods were stock and were balanced along with the pistons. I went with Kolbenschmidt euro flat top pistons and barrels. Machine work was done in Torrance, I don't remember the name of the place. Flycut the heads and case for barrels, line bored the case one over to true up the case for the new crank. ARB fasteners, case savers and had the oil plugs on the back of the case (between case and flywheel) removed and welded up. When you decide what type of fuel delivery you'll use, you can speak to someone about a cam. @shivers sounds like a work of art thank you, leaning towards carbs more and more everyday! |
bbrock |
Jan 19 2021, 09:15 AM
sounds like a work of art thank you, leaning towards carbs more and more everyday! In the late 80s I tore down my engine and rebuilt the short block. The original FI had become unreliable and be pre-Internet days, info on how to restore it was unavailable so I installed a carb cam and bought a pair of Webers. Then the project went on hold for decades and I am just now finishing the engine. I'm kind of "stuck" with the Webers. I'm excited to learn how they perform, but if I were to do this over today, I would have definitely stayed with the original D-Jet FI and may yet go back to it after running these carbs for a few years. Among other downsides to carbs is that the induction noise can be quite loud. Some people like it and others have gone as far as wearing ear plugs when they drive. Neither were appealing to me for daily driving or comfortable touring so I built a custom air intake to silence them. Time will tell if it works. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1606710294.jpg) |
Lo-Fi Version | Time is now: 25th May 2024 - 06:01 AM |
