Bearing Bracket for clutch roller, Can the stud be replaced? |
seanpaulmc |
Jan 17 2021, 05:24 PM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
The bearing bracket, 914 423 030 02, for the clutch roller has what looks like a pressed in stud. Can this stud be simply pressed out and replaced?
If so, what are the specs of the stud? I haven't been able to locate the details. As you can see from the photos, this one is both sheared and stripped of threads. Thanks in advance! |
fixer34 |
Jan 17 2021, 05:28 PM
Senior Member Group: Members Posts: 1,076 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I'll ask a silly question. Why not just buy another used/new bracket? I would think they are readily available and not too expensive.
bdstone914 |
Jan 17 2021, 06:20 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[quote name='seanpaulmc' date='Jan 17 2021, 05:24 PM' post='2883709']
The bearing bracket, 914 423 030 02, for the clutch roller has what looks like a pressed in stud. Can this stud be simply pressed out and replaced? If so, what are the specs of the stud? I haven't been able to locate the details. As you can see from the photos, this one is both sheared and stripped of threads. Thanks I have a bunch of them that have good threads and are yellow zinc plated for $25 shipped. @seanpaulmc |
davep |
Jan 17 2021, 10:58 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It does appear to be pressed into place, and you will lose nothing by trying to press it out. Other than that, purchasing a replacement for $25 is a great deal compared to the effort of a repair. I would also try to get a correct nut for the stud.
Superhawk996 |
Jan 18 2021, 10:25 AM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Stud is likely resistance welded to bracket and isn't going to just press out.
If you're going to press it, you can try lightly but don't expect it to budge. Forcing it may or may not break the resistance welding under the head and will likely deform the bracket. Grind head off, then press stud shank out is the best bet. But then on the "Fix" side, you will need to weld the stud back to the braket to keep it from wobbling and rotating when you try to install the roller. Agree with comments above. Just replace the bracket. Easy simple, cost effective. |
seanpaulmc |
Jan 18 2021, 01:10 PM
Replacement it will be! Thanks for the responses.
Cheers, Sean |
Mikey914 |
Jan 24 2021, 04:35 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Disregard just noticed the threads
bkrantz |
Jan 24 2021, 08:53 PM
914 Guru Group: Members Posts: 7,742 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Disregard just noticed the threads Just do like the PO of my car would have done: find a nut, probably SAE size, that can be jammed on (and maybe not perpendicular to the stud). (IMG:style_emoticons/default/blink.gif) |
Mikey914 |
Jan 25 2021, 04:47 PM
Looks over tightened. The 1st few threads are ok. But if you keep tightening you loose threads.
Lo-Fi Version | Time is now: 2nd May 2024 - 07:46 PM |
