Need Help...What's the best way..., to get rid of the backpad glue? |
nine14cats |
Jul 17 2005, 05:00 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I've got back pad glue I need to take off to prep the engine bay for paint.
What's the best method? Thanks, Bill P. |
nine14cats |
Jul 17 2005, 05:02 PM
icky poo.... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Bill P. Attached image(s) |
J P Stein |
Jul 17 2005, 05:06 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I've found stuff that takes it off (albiet slowly), but also takes off the paint. I've never tried Goof Off, tho......sand blasting seems to work well (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
texanpilot |
Jul 17 2005, 05:13 PM
Newbie Group: Members Posts: 25 Joined: 20-November 04 From: Hartford, CT Member No.: 3,150 |
I just stripped the glue off of both the inside firewall and the engine compartment using terry cloth rags and lacquer thinner. Worked great and left the panels clean.
rhodyguy |
Jul 17 2005, 05:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
6 tough hours. berrymans, gumout carb cleaner worked for me too. spray it on, let it work a bit and hit it with the big rightangle grinder. it's messy. i set a short stool in the engine comparment to sit on.
k |
SirAndy |
Jul 17 2005, 05:15 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
lots of brake cleaner and a rag ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
J P Stein |
Jul 17 2005, 05:18 PM
Hay, Bill, didja get my reply to your PM?
grasshopper |
Jul 17 2005, 05:19 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
another tip, take the engine lid off, it give you more room to work... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
neo914-6 |
Jul 17 2005, 05:33 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
(IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) a bulkhead out of a parts car, chrome plate it, and screw it on over the mess, more insulation and will reflect all the nice Renegade parts you are hiding... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
That or buy a new heat shield and mount it. Is there rust or do you just want a clean painted engine compartment? Goop off should work and it's not too smelly or brain damaging. |
Randal |
Jul 17 2005, 05:49 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Just did that wonderful job before having my engine compartment painted. Just looking at your picture brought back the memories Bill.
What worked the best was adhesive remover (HD), but in the end it took off the paint as well, so I just stripped it clean. Apply remover. Let sit 25-30 minutes Clean off with power washer Start again. Took 3 times to get it perfect, but it wasn't hard work. MAKE SURE YOU HAVE ALL THE CAR PAINT COVERED; OTHERWISE YOU'LL BE PAINTING MORE THAN YOU WANT. Brake cleaner works, but it does take a huge amount of time. And I don't know if you'd have any brain cells left after smelling that stuff for 5 or 6 hours. |
SirAndy |
Jul 17 2005, 06:56 PM
naaa, you just need to do it the right way. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) apply brake cleaner *generously* over a area the size of a shop rag. let it sit for at least 30 sec. rub hard with a shop rag. you'll probably have to do that twice per area to get it clean. that's it! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy PS: the trick is that you'll need to let it soak, if you try to wipe it right away or put brake cleaner on the rag and wipe, you'll be there forever ... |
Trekkor |
Jul 17 2005, 06:58 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
The old glue is pretty dried out and crumbly to the touch, huh?
Mine was. Just take a single edged razor blade on it's edge and scrape away. Work at a 90 degree angle. It will just fall away faster than you thought possible. Short strokes. When you get most of it off wipe the whole area down with a rag and acetone ( brake cleaner ). When the razor loses it bite, toss it and try another. Very simple and non stinky. You'll be blown away when you see how far you've come after just one hour. KT |
Lo-Fi Version | Time is now: 20th May 2024 - 02:11 PM |
