911 style muffler bracket and straps infomercial |
mb911 |
Jan 21 2021, 07:29 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I thought this is a needed information for the group. I have been sending brackets and straps with the mufflers for a while but recently switched to a better strap that I have laser cut but isn't as bulky as the old ones but does require you to bend them around the muffler to form them. It takes 10 seconds per strap to do. Below you will see the straps as they come, then after you bend them around the muffler and then of the bracket for reference. Let me know if you have any questions. Also note these are designed to protect your investment from failing prematurely. The factory design is pretty silly and cantilever the muffler. Ugh
mb911 |
Jan 21 2021, 07:30 AM
campbellcj |
Jan 21 2021, 08:14 AM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
(IMG:style_emoticons/default/first.gif) I've been super happy with your bracket - got the right sizes of straps like those at McMaster Carr that fit the couple different mufflers I have.
VaccaRabite |
Jan 21 2021, 08:37 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Is there an advantage to these straps over the T-bolt clamps you had been using? Cheaper? Stronger?
Also, in the first picture is the nut welded to the strap and captive? Trying to figure out the lack of a washer on it. Having used Ben's muffler hanger - its much better then the stock hanger. Thanks! Zach |
mb911 |
Jan 21 2021, 08:46 AM
Sorry the washers are not oriented correctly they should be on each side. The nut is not captive. The reason for the switch is these are stronger then the ones I was using and a bit more hidden. I felt they were just a better way to finish out the install.
Lo-Fi Version | Time is now: 15th May 2024 - 01:54 PM |
