More Questions, Does anybody know the Centerline to Centerline between the Carbs? |
Beebo Kanelle |
Jan 21 2021, 04:36 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Does anybody know; Or, can anybody measure the longitudinal centerline to centerline between the carburetors on the T4 engine?
Thank you |
IronHillRestorations |
Jan 22 2021, 08:13 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Too many factors for a standard measurement; manifolds, gaskets, spacers, etc. I recently worked on a kind of a Frankenmotor that wasn’t symmetrical
Mark Henry |
Jan 22 2021, 09:07 AM
(IMG:style_emoticons/default/agree.gif) My stroker engine is around 3/4" wider than a stock engine.
Ballpark stock engine outer intake manifold stud is a bit over 24" If you're measuring for something say linkage don't do this until you have a completed long block. |
SirAndy |
Jan 22 2021, 03:49 PM
Resident German Group: Admin Posts: 41,617 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Too many factors for a standard measurement; manifolds, gaskets, spacers, etc. (IMG:style_emoticons/default/agree.gif) |
Jan 23 2021, 02:30 PM
I was installing a CSP bellcrank linkage on the engine I mentioned and I had to space the center bellcrank to one side so it was perfectly centered between the two carbs. This was the 3rd CSP I’ve installed and the only that needed that
Lo-Fi Version | Time is now: 4th May 2024 - 03:03 PM |
