Once more with feeling - sourcing vacuum nipple for Weber or EMPI IDF |
Tdskip |
Jan 22 2021, 12:25 PM
@BK911
- may I ask where did you source the vacuum nipple? I've been looking but utterly no luck in finding one. I know that is where they go but finding a vendor that has them as been super frustrating. Related to this thread; http://www.914world.com/bbs2/index.php?showtopic=351129 |
Tdskip |
Jan 23 2021, 09:54 AM
First of all thank you for all of the help and responses. I hope everybody had a good week.
When I unscrew what Brock circled I do not have a nipple/fitting for a vacuum line, it’s just open. The link to the Del shop that @rfinegan with the threaded part number 71 looks like the ticket, I’m assuming the threads on a dell will be the same on a Weber or EMPI? |
bbrock |
Jan 23 2021, 10:07 AM
First of all thank you for all of the help and responses. I hope everybody had a good week. When I unscrew what Brock circled I do not have a nipple/fitting for a vacuum line, it’s just open. The link to the Del shop that @rfinegan with the threaded part number 71 looks like the ticket, I’m assuming the threads on a dell will be the same on a Weber or EMPI? I'm not sure I'm understanding. The end result is essentially the same with either version. You just need to get a hole into the right location on the carb you can attach a vacuum hose to. I think the only real diff between the del and weber versions is that the del threads in vs a press fit. Here's might with screw plugs removed and hoses attached. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1608516367.jpg) |
Lo-Fi Version | Time is now: 18th May 2024 - 05:29 PM |
