aux Venturi Weber 44 IDF dented cracked at top, can these be machined down shorter? |
rfinegan |
Jan 24 2021, 03:04 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Just picked up a set of weber 44 Idf carbs and 2 of the aux venturis have damage . Can the ventures be machined down to remove the damage (all 4 the same height) Shorter?
Also the main jet stacks are Short? Is the jet holders available in both short and long? Any preferences in performance? I noticed one carb has a notch in the top cover in the inside diameter near the bore. any idea what this was for and the other carb does not have this? Attached thumbnail(s) |
rfinegan |
Jan 24 2021, 03:24 PM
johnhora |
Jan 24 2021, 04:02 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
just replace the AVs there should be plenty of parts around...someone here will probably have some extras.
the Emulsion Tube Holder / stacks are fine with good filters.. check here for the AV: https://www.piercemanifolds.com/SearchResul...sp?Search=69002 here for the tube: https://www.piercemanifolds.com/SearchResul...earch=52580.006 |
Lo-Fi Version | Time is now: 4th May 2024 - 06:09 AM |
