1.7 rockers & Swivels, Spacers which ones |
DavidSweden |
Jan 25 2021, 04:20 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
2.0 motor
I have some 1.7 rockers with 911 swivels which I am thinking about installing. Questions: Will type 2 Vanagon spacers (part 021109433) fit the 2.0 rocker shafts? Will I need new push rods? Thanks in advance |
914werke |
Jan 25 2021, 06:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes, but to do it right you should install & measure your adjuster to tip alignment & shim (or machine) accordingly
Mark Henry |
Jan 25 2021, 07:03 PM
Is this a stock or stock-ish 2.0?
There's little to be gained on a stock engine other than a lot of extra work. I use 1.7 rockers and SF adjusters on performance engines where I use HD dual springs with pressures that will damage the stock adjusters and the valves. |
Lo-Fi Version | Time is now: 9th May 2024 - 03:23 PM |
