Fuel injection wiring harness, Which replacement harness? |
71six |
Jan 26 2021, 04:45 PM
Member Group: Members Posts: 135 Joined: 4-July 03 From: Fitzwilliam,NH Member No.: 884 |
My 73 914 2.0 needs a complete replacement fuel injection wiring harness I am told. I am aware of the ones from 914 Rubber and Jeff Bowlsby. They both look good to me so should I just flip a coin to determine the winner or are there pro's and con's I should be aware of? All opinions and advice appreciated from those in the know.
Thanks, Mark |
914Sixer |
Jan 27 2021, 07:23 AM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have 3 of Jeff's harnesses. Alt, relay board and fuel injection.
Mark Henry |
Jan 27 2021, 09:18 AM
Jeff has been doing this for a long time, I entered the 914 scene 20 years ago and he was well established then.
Plus I've had dinner with Jeff (several years ago) and he's a super nice person, so I'm a bit biased on who I'd use. (IMG:style_emoticons/default/biggrin.gif) |
rjames |
Jan 27 2021, 10:43 AM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I bought both an injection and ignition harness from Jeff. They are works of art and he was great to work with.
Mcraneiowa |
Jan 27 2021, 05:04 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
The only comment I’d make as both mentioned are excellent providers, are all connections furnished on the new harness or do you have to use your old connections. If one has everything included, where the other asks you to use your old connectors to complete the harness, I know the route I’d go. Just my $.02 worth.
JeffBowlsby |
Jan 27 2021, 05:44 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The harnesses I build are complete plug 'n play and everything is included. Every part is new and the highest quality available, but I do reuse some of the serviceable hard plastic parts where they are NLA or not otherwise available. New heat treated wires, new OEM wire terminals, new high temp resistant boots in the factory update design (much more durable than the original design boot), and new casing. Grey outer casing to match the original OEM. For a D-Jet FI harness, you will need to mount your existing ECU handle piece...the part is NLA and yours should be perfectly good. If your handle is missing or broken, I am happy to include a replacement free if you just ask.
Attached thumbnail(s) |
Amphicar770 |
Jan 27 2021, 05:58 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I also installed Jeff's harness. Top quality product.
71six |
Jan 28 2021, 04:26 AM
Thank you everyone for your helpful responses to my inquiry. I have placed an order with Jeff Bowlsby for a complete harness for my 1973 2.0. Grateful to the 914 World community for their guidance on this and numerous other questions throughout the years. (IMG:style_emoticons/default/smile.gif)
Mark |
Lo-Fi Version | Time is now: 4th May 2024 - 10:43 AM |
