Sideshifter shifter rotators left/right around 45 degress |
Tdskip |
Jan 28 2021, 10:32 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning - film at 11 but trying to sort out a new to me 914 with a sideshifter and haven't come across this issue yet.
The car actually shifts great (gearbox and syncros etc) but the shift rod will rotate around 45-degrees from side to side in my hand. Imaging looking straight down on top of the shifter and then pivoting the ball/rod 45-degrees from side to side. I've tried to illustrate that with the red curve I added to this schematic below. That seems to suggest that either #9 or #11 are very worn and ovaled out maybe? Thanks in advance for any thoughts or experiences. |
Mikey914 |
Jan 28 2021, 10:38 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes it's at the base where it attaches to the "ball". You can remove, clean it up, scuff it, and epoxy back in.
Tdskip |
Jan 28 2021, 12:19 PM
Thank you
914werke |
Jan 28 2021, 12:24 PM
"I got blisters on me fingers" Group: Members Posts: 10,072 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Weld it
Tdskip |
Jan 28 2021, 02:48 PM
914werke |
Jan 28 2021, 03:24 PM
ClayPerrine |
Jan 28 2021, 03:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Weld it OK - now I think I get it, the shaft near #9 is what is rotating so a bead of weld there will fix it. Yes? Yes... but make sure you take it completely apart because there is a plastic bushing in the shifter base you will melt when trying to weld it. Clay |
Montreal914 |
Jan 28 2021, 03:37 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Also, I had one that had been repaired with a big weld and was coming into contact with #1 when shifting the arm from side to side limiting its movement.
Tdskip |
Jan 31 2021, 02:04 PM
Thank you for all of the considerations – I was able to fix this this morning and nobody say that it shifts really-really well now.
Lo-Fi Version | Time is now: 19th May 2024 - 10:09 AM |
