Low Rear End |
Low Rear End |
rickso71 |
Jul 17 2005, 10:19 PM
Member Group: Members Posts: 74 Joined: 31-October 04 From: Derry, NH Member No.: 3,041 |
Finally got the engine installed and back on its tires and about 1" of the rear tires are covered by the fenders and there's a gap of about 1" between the front tires and the fenders. Looks a little silly and since I've never seem the car with the engine in, don't have a 'before' to compare to. The fuel tank's almost empty (1gal.?) and the spare is in place.
I know I can adjust the front height down some but do I need new rear springs to raise the rear? |
Aaron Cox |
Jul 17 2005, 10:20 PM
what rear shocks/springs do you have? original?
rickso71 |
Jul 17 2005, 10:49 PM
Don't know what's original. The shocks are orange and the springs yellow, if that means anything.
Aaron Cox |
Jul 18 2005, 12:06 AM
Orange- replacement Boge shocks Yellow- probably an aftermarket 'lowering' spring. about an inch and a half shorter than stock....combine that with a tired spring, and you have a low rear end.... lower the front (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) or get a spring/shock combo with an adjustable perch to play with rear ride height (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Joe Ricard |
Jul 18 2005, 06:02 AM
Lower the front till you are happy. give it about a 1/2 tank of gas. turnthe two adjusters onthe front A arms till they are level to the ground. that'll make the butt look too high.
Should be level or slightly raked to the front. SLIGHTLY. |
Lo-Fi Version | Time is now: 9th May 2024 - 10:46 PM |
