Tangerine Racing Shift Linkage, Installation Question |
1adam12 |
Jan 30 2021, 04:31 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Received Chris's 4cyl shift linkage kit this week and I'm trying to install Tangerine's shift rod through the shift counsel. Do you need to enlarge the coupler that it passes through? Just like the stock shift rod, it stops just at the back side of the coupler that's connected to the selector.
ChrisFoley |
Jan 30 2021, 05:35 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I thought everything was well covered in the instructions.
Can you point to a step number where you're having trouble? |
1adam12 |
Jan 30 2021, 05:54 PM
Hey Chris! I'm at steps 7-10. I've already installed your mounting bracket into my now modified shift counsel. The rear of the shift rod piece doesnt pass through my shift selector coupler. I'll take a pic.
I thought everything was well covered in the instructions. Can you point to a step number where you're having trouble? |
1adam12 |
Jan 30 2021, 06:01 PM
1adam12 |
Jan 30 2021, 06:06 PM
So if you look at where the rod stops in the counsel, that's were it gets hung up. I'm wondering if there's something aloof about that coupler. I pulled it off a donor car and it was shimed with aluminum originally and has always been loose since I installed on my car.
ChrisFoley |
Jan 30 2021, 06:44 PM
It should slide all the way to the cone screw hole.
The bore in the shift rod head is probably buggered a little bit. |
1adam12 |
Jan 30 2021, 06:54 PM
ChrisFoley |
Jan 30 2021, 07:04 PM
One more thing - I usually finish the short shaft installation before attaching the universal joint.
VaccaRabite |
Jan 30 2021, 07:53 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You are going to love this once it done and dialed in. It will be stiff at first but I either got used to it or it broke in. But shifting is SO much cleaner now all the way around.
Zach |
gereed75 |
Jan 30 2021, 10:52 PM
Senior Member Group: Members Posts: 1,247 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Been awhile since I put mine in, but yep gotta get the shift rod to slide all the way through the selector lever and into the back bearing.
Then it will take some length adjustment to make it all work right. But when it does this setup absolutely transforms 901 shifting. Mine has a Weltmiester short shift also and I can say it actually is a pretty short precise gear change ( once out of first and into the H) Best money I spent on the whole car! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:07 PM |
